Ookke said:
By the way, is the falling object really there hovering just above the horizon infinitely (in outside observer's frame), or do we see just an image of the falling object, but the object itself has actually fallen below event horizon?
It's more than just an image. It actually
is the object (as measured from your frame of reference).
But it gets complicated. And my last post made several assumptions and approximations. Allow me to elaborate.
My x' = d \left[1 - \mathrm{sech}\left(\frac{c}{d} \tau \right) \right] equation (the distance,
x', from "stationary" observer to an object dropped at close range into the event horizon of a super-massive black hole [event horizon a distance
d away;
d \ll
r]) doesn't describe a few details, and made some assumptions. Perhaps it would be fair too describe a few more details and the impacts of the assumptions.
Mass of the object:
One of the assumptions in my equation is that the object has negligible mass. It ignores the any spacetime curvature caused by the object itself. What impact does this assumption have? Well, if we don't ignore the mass of the object then as the object approaches the event horizon, it can affect the local spacetime around the horizon nearby it, causing a little "dimple." So does the dimple overtake the object (such that you would observe the object cross the horizon)? That's not a simple answer: the event horizon is not "well behaved" in such situations. I don't have the mathematical skills to analyses it from that aspect. But what I can say, is that you wouldn't observe it "shooting" right through. It would slow down to a snail's pace, at the very least. And what you are observing is not an "image" but rather the actual object.
Time dilatation, Doppler, and resolution:
A detail that I have yet to describe is the Doppler red-shift you would observe on the object quickly becomes enormous.
Imagine that the object you drop in the super massive black hole is a clock. (I'm using the same scenario where you are suspended above the event horizon of the black hole by a cable or something, a constant distance
d above the horizon, such that
d \ll the black hole's radius
r. Suppose you release the clock from your hand at \tau =
t' = 0. The time that you observe on the clock, from your frame of reference, is
t' = \frac{d}{c} \tanh \left( \frac{c}{d} \tau \right)
If you plot that out, the time you observe on the clock approaches
d/c, but never reaches it.
Now imagine the clock is transmitting its time by using some sort of radio source. Every second it transmits a pulse. The time interval between pulses become farther and farther apart. Better than pulses though, let's assume the clock is transmitting its time by continuous gamma rays, and you can observe the clock's time by counting the number of wavelengths received. As the clock approaches the horizon, the gamma rays emitted by the clock come increasingly red-shifted: the frequency becomes smaller and the wavelength becomes larger. Suppose the original frequency and wavelength of the gamma rays, when you are holding the clock are f_0 and \lambda_0 respectively (btw, c = \lambda f). As the clock approaches the horizon, these become,
f = f_0 \left[1 - \mathrm{tanh}^2 \left(\frac{c}{d} \tau \right) \right]
\lambda = \lambda_0 \mathrm{cosh}^2 \left(\frac{c}{d} \tau \right)
The ability to determine the position of an object, purely by measurement/observation, is inversely proportional to the wavelength used for the measurements.
The point of all of this is as the object approaches the horizon, not only is it red shifted to point of "disappearing" from sight, it's location becomes more difficult to determine by observation alone. (Eventually the wavelength will exceed the diameter of the black hole itself.)
Other things in the vicinity.
Being held by a cable from above, that allows you to be close the event horizon of a black hole would not be a pleasant thing at all. The acceleration from the cable holding you there would be so great that you'd be smashed to bits. Also, any light coming from above would be so incredibly blue-shifted that it would fry you instantly.
The scenario I described assumes that everything around the black hole is very calm (which it wouldn't be in reality), including lack of other stars in the sky creating light, etc.
There's also an assumption that you are somehow able to survive the extreme forces of being held in place above the horizon (which in reality, you wouldn't).
Quantum effects:
Thus far in my simple description, quantum effects are completely ignored. They're outside the scope of this thread anyway, so I'm not going to discuss them here. (Not that I would be able to discuss much anyway.)
Now back to Ookke's post.
I think this is physically relevant and related to the question "will the falling observer see universe end". This is a well known question with different answers on the internet (not much to do with the original subject though), any opinions in this forum?
If you were to reach back and cut the cable, so that
you fell into the supermassive black hole, things would be quite different.
You would cross the event horizon after about
d/c (units of time) from when you cut the cable (again this assumes that
d \ll
r, so we can ignore tidal effects), as measured by your (new) frame of reference. When you did cross the horizon, it would pass you at the speed of light, but wouldn't appear to be anything special.
Remember that clock/object that you dropped into the black hole at some time before? It would now be moving away from you at a constant velocity. Until you got closer to the center of the black hole(when tidal effects come into play), the rules of special relativity of simple, non-accelerating objects apply.
I don't know what the "end of the universe" means, but however you define it, if you didn't see it before you cut the cable, you wouldn't likely see it when you crossed the horizon.
If the object is really there, it seems to me that a photon (with proper direction and constant speed c) should eventually reach the falling object, no matter how far the photon was send from. So the falling observer would see the universe end in this case, but if it's just an image, then not.
As you've figured out, something falling through a black hole brings up seeming paradoxes. According to the math, observing something from a "stationary" viewpoint is quite different than what is observed by an observer free-falling though the horizon.
I'm not going to discuss the attempted resolutions to the paradoxes here [doing so might even violate the Forum guidelines]. But if you want to explore further, Leonard Susskind and Gerard t'Hooft might be good resources.
Here is a link to a paper by Susskind:
http://arxiv.org/abs/1301.4505
