What is the significance of cubic in a cubic spline?
  • Thread starter basty
  • Tags
    Cubic
In summary: If you're trying to analyze that a spline is C2, you can expect that the first and second derivatives of the curve should be continuous at all endpoints.
basty
95
What is the meaning of "cubic" term in a cubic spline?
Is it mean a spline with a degree of 3?
Mathematics news on Phys.org
Yes. A spline is a mechanical device which is used to draw a curve which passes thru several known points.
A cubic spline is a mathematical equation which replicates what the physical device is used for: creating a smooth curve which passes thru all the data points. The equation is a polynomial of degree three in this case. There are other formulations used, but cubic splines are very common and easy to construct.
http://en.wikipedia.org/wiki/Spline_interpolation
Splines are useful for interpolating data in between the fixed points used in their development.
Does this mean a quadratic spline is a spline with degree 2?
Is there availabe a quartic, quintic, and so on, of a spline?
What is the difference between quadratic and cubic spline?
Yes, the differences between all those curves are really a matter of polynomial degree. Quadratic splines can interpolate the same data points that cubic splines can, but it doesn't have quite the same shape. You can imagine a quadratic spline being a series of parabolas that you're trying to string together to run through the data points and maintain a certain continuity. Cubic splines are like that in much the same way, and quartic, quintic, etc.
Splines are interesting because they form the math basis of computer-aided design. Because of numerical errors, generally lower-degree splines are nicer to work with, but you can't really go too low without getting some interesting effects. For example, cubic splines are usually used because you can achieve what's called C2 continuity. The math is kinda cool, but this has effects in the real world. For example, car bodies are usually C2 because if they weren't they wouldn't look smooth in a showroom because it wouldn't have smooth reflection lines.
In theory, you could produce higher order splines, but the math becomes more complex with increasing order. Higher order splines tend to oscillate as well, and sometimes fail to produce a smooth curve which passes thru the data points.
The cubic spline is the formulation which most closely mimics the elastic behavior of a physical spline.
Quadratic interpolating splines can also be developed, but due to the nature of the resulting curve (a parabola), these splines are not as widely useful as the cubic. Quadratic interpolation is, however, used as the basis for developing Simpson's First Rule of numerical integration, while cubic interpolation forms the basis for Simpson's Second Rule.
What kind of numerical error it is?
Is it such as any number divide by 3 (such as 1/3, 2/3, 4/3, 5/3, 7/3. and so on) as the result is not being an integer (such as 1.33333, 0.6666667, and so on)?
What is C2 continuity?
Could you give an example?
Part of it is due to truncation error because of the finite number of bits that represent the number (like 1/3 = 0.33333... but also that 0.1 can't be accurately represented in a finite number of bits in binary). Increasing precision can help, but only to a certain degree. The other part of it is due to numerical stability (i.e. how susceptible the polynomial is to small errors in numerical values). Numerical stability is why splines in CAD are generally represented in the Bernstein basis rather than in the power basis. Larger polynomials generally are less numerically stable, so cubic splines are the de facto standard because it's the lowest degree that can we can force C2 continuity with.
In a matter of speaking, a spline is basically a bunch of curves strung together. For example, a B-spline can be represented as a series of Bezier curves. However, when you string curves together, you can control how continuous you want the resulting spline to be. Curves that meet at an endpoint only are said to be C0 continuous (usually seen as a sharp point there). If the curves are C0 and also the derivatives of the curves (tangent lines) are equal at that endpoint, the curves are said to be C1. If the curves are C1 and the second derivatives are equal (osculating circles or curvature) there, then they are C2. C2 continuity is important for a lot of reasons. I already mentioned the smooth reflection lines on a car hood. If you're designing a set of train tracks to meet, C2 continuity ensure that there is finite jerk (derivative of acceleration) at the point where they meet.
1. What is a cubic spline?
A cubic spline is a mathematical function used for interpolation or approximation of data points. It consists of multiple cubic polynomial segments connected at specific points, called knots.
2. How is a cubic spline different from other types of splines?
Cubic splines use cubic polynomials, which have a degree of 3, to connect data points. This allows for a smooth and continuous curve, unlike linear or quadratic splines which use lower order polynomials and can result in sharp corners or discontinuities.
3. What is the purpose of using a cubic spline?
Cubic splines are commonly used in data analysis and computer graphics to approximate a curve or function that passes through a set of given points. This allows for a smoother and more accurate representation of the data.
4. How are the knots determined in a cubic spline?
The knots in a cubic spline are determined by the input data points. The spline will pass through these points, and the knots act as "anchor points" to ensure a smooth and continuous curve. The number of knots used can affect the overall accuracy of the approximation.
5. Can a cubic spline be used for extrapolation?
While cubic splines are primarily used for interpolation, they can also be extended for extrapolation by adding more knots outside of the given data points. However, this can result in less accurate predictions and should be used with caution.
  • General Math
  • General Math
