What is causing an error when opening a PPM image file in Python?
  • Context: Python
  • Thread starter Thread starter ard12
    Image Python
1 reply · 5K views
ard12
I'm writing a program that will do simple image editing with ppm files. I can only use the graphics library and things in there. No PIL or Image module.
My problem is that I get an error that says "couldn't recognize data in image file "sole.ppm"
I know for a fact it is a correct ppm file.
Here's my code:
Code:
def main():
print("Image Editor")
print()
filename = input("name of image file: ")
print()
with open(filename) as f:
    formatind = f.readline()
    width, height = [int(x) for x in f.readline().split()]
    colordepth = f.readline()
    array = []
    for line in f:
        array.append([int(x) for x in line.split()])
win = GraphWin("Image Editor!", width, height)
image = Image(Point(100,100), filename)
Display(image, array, width, height, win)
inf.close()
win.getMouse()
win.close()
main()
And my display function looks like this:
Code:
def Display(image, array, width, height, win):
for i in range(width):
    for j in range(0, height, 3):
        colors = color_rgb(array[i][j], array[i][j+1], array[i][j+2])
        image.setPixel(i, j, colors)
        image.draw(win)
return
I just cannot figure out what's wrong with this. Any help would be great. Thanks
I've just figured out that it's because of the format indicator. My file is P3. The Image constructor I used is not compatible with P3. I changed my file to P6 and it recognized the data. So I need another way of declaring an Image object for P3 format ppm file. Any ideas there?
