What is centripital acceleration physically?
  • Context: High School
  • Thread starter Thread starter R Power
    Acceleration
The discussion centers on the physical meaning of centripetal acceleration, exploring its relationship with forces, motion, and geometry, particularly in the context of circular motion and vehicle dynamics. Participants seek to clarify the concept and its implications in various scenarios, including everyday examples like cars turning and objects in orbit.
  • Some participants describe centripetal acceleration as the acceleration resulting from a centripetal force, which is necessary for maintaining circular motion.
  • Others emphasize that centripetal acceleration is related to the rate of change of velocity due to changing direction, highlighting its geometric nature.
  • A participant mentions that centripetal acceleration can be expressed mathematically as speed squared over the radius of curvature.
  • There is a discussion about oversteer in cars, with some suggesting that it could lead to theoretically infinite centripetal acceleration under certain conditions, while others challenge this notion.
  • One participant explains that centripetal acceleration is always directed inward toward the center of the circular path, affecting the motion of objects like yo-yos swung in circles.
  • Another participant questions the necessity of defining centripetal acceleration, suggesting that angular acceleration could also describe changes in direction.
  • Some participants clarify that centripetal acceleration is distinct from angular acceleration, as it specifically refers to the change in velocity due to direction change.
Participants express a range of views on the definition and implications of centripetal acceleration. There is no consensus on the relationship between centripetal acceleration and angular acceleration, nor on the implications of oversteer in vehicles. The discussion remains unresolved with multiple competing perspectives.
Some participants note that the understanding of centripetal acceleration depends on geometric interpretations and the specific conditions of motion, such as speed and radius of curvature. The discussion also touches on the complexities of vehicle dynamics, which may require specialized knowledge to fully grasp.
R Power
Hi friends
I know it's a very elementary question but i wat to know what centripetal acceleration physically is?
I mean, acceleration is something that results due to any force. In case of centripetal acceleration, the force is centripetal force (which e.g in case of car making turn is provided by tyres friction) and this force tends to bind the body to revolve around a center.
Now, acceleration is basically, rate of change in velocity along a certain path or distance.
And in case of circular motion the rate of change of angular velocity is angular acceleration,
then what's centriptal acceleration?
R Power said:
Hi friends
centripetal means "center seeking". It's not a fundamental force itself, it's more of a scenario that involves a fundamental force.
Orbit is a common example. An object must have the right velocity to orbit Earth. The planet's gravity is pulling it in. Since the velocity is just right, it continues in orbit, always being pulled toward the center of Earth, but never really getting closer.
Notice that the velocity is directed slightly opposite of the force pulling it in. With the right velocity, it's just enough so that it's always correcting itself due to the force, perpetually orbiting.
A more personable example is when you're taking a turn in your car. Your velocity is still going straight, but you're turning the car, so the car's driver side door pushes on you as it turns and makes you turn with it. Here, the door is exerting a centripetal force on you.
Yeah, I understand centripetal force as you explained too but what I ask is that what is centripetal "acceleration" physically?
Velocity has both magnitude (speed) and direction. For circular motion, the centripetal acceleration is the rate of change of the velocity due to its changing direction.
that means in case of cars, in case of oversteer we get theorotically infinite lateral or centripetal acceleration
What makes you think that?
geometry, not physics
Hi R Power! :smile:
It isn't.
Centripetal (same root as "petition", from the Latin for "seek" :wink:) acceleration is geometry, not physics.
Anything going along a curve has a centripetal acceleration equal to speed squared over radius of curvature. :smile:
The same vector conventions apply to the acceleration. As Doc Al said, a change in direction of velocity is an acceleration (so is a change in magnitude, of course, like when you speed up on a straight road).
Using the vector conventions, you can see how the velocity of the object changes at every point around it's orbit (because of the centripetal force acting on it).
in case of cars lateral acceleartion is dependent upon square of velocity as well as cornering stiffness constant (which is directly related to slip angles of rear and front wheels). In case of oversteer slip angles of rear wheels are greater so CSC becomes negative and at critical speed it becomes 1 and when we relate it to lateral acceleration
through a certain derived formula we get infinite lateral acceleration.
You may not understand the above text if you don't have considerable knowledge of vehicle dynamics.
I was just confused what infinite centripetal acceleration means, and now I just undestand that infinite acc will create a slip.
Centripetal acceleration just means an acceleration that is perpendicular to an objects current direction. The resulting path will be circular or spiral like. One example of a spiral like path produced by centripetal acceleration is called involute of circle, which is the path of an object connected to a string that winds or unwinds around a post.
http://mathworld.wolfram.com/Involute.html
oversteer ... infinite centripetal acceleration
A car can only experience a finite amount of centripetal acceleration, regardless of oversteer. Oversteer has two basic meanings. One usage is when the rear tires have more slip angle than the front tires, a situation that only exists when a driver is countersteering in the direction of a drift or skid. The other usage describes the tendency for the rear end to drift or slide more than the front end while turning near the limits of traction.
If you draw a picture of a car traveling in a straight line from above, this is easier to understand. Draw a straight behind and in front of it depicting the path of the tyres on the ground.
Then under cornering when centripetal forces make it go in a circle, you'll notice that the path carved by the tyres is circular. Centripetal force in this case, is from the tyres pushing the car away from its straight-line path into a circle. The force you feel as a passenger is the seat and car-door pushing in from the outside and making you go in a circle. In the case of a rear-seat passenger who isn't paying attention, this force can come from the window against their face.
There's some equations for you in this Physics of Racing chapter.
mV^2/R = ma => a= V^2/R This is basically centripetal acceleration, in case if you are really asking this.
From what I understand centripetal acceleration is the type of acceleration that causes circular motion. For example of you swing a yo yo around your head the direction is constantly changing and therefore so is the velocity, if the velocity is changing then the yoyo has an acceleration. Now as for the direction of this acceleration? well if the yo yo is being swung in a circle it is pointing inward down the line of the yo yo toward your hand. So the acceleration vector points along the radial line voila.
To show this more rigorously . Choose a point P on a path of circular motion and draw its velocity tangent to the path of motion. notice the angle theta swept out by the velocity vector as it changes by magnitude delta v is the same angle as is swept out but magnitude of v during a change in time dt and so you can write (d v)/v =v(d t)/r and it follows that dv/dt=v^2/r this is the expression for centripetal acceleration. Like someone already stated, its a consequence of the geometry of the situation. Angular acceleration, however is a direct measure of how fast the rate of rotation wrt time.
I do not get it properly, can you explain a bit more in detail.
I am confused that what is the need for defining centripetal acceleration. Rate of change of direction can be given by angular acceleration also because angular acceleration is rate of change of angular velocity as well as direction!
Centripetal acceleration is not the rate of change of direction--it's the rate of change of velocity due to changing direction. For an object in uniform circular motion, the angular acceleration is zero but the centripetal acceleration is certainly not zero.
Here's a derivation of the centripetal acceleration formula: http://hyperphysics.phy-astr.gsu.edu/HBASE/cf.html#cf2"
And another version of the same thing: Derivation of the Formulas for Centripetal Acceleration
  • · Replies 33 ·
  • · Replies 16 ·
  • · Replies 37 ·
  • · Replies 22 ·
