What is purpose of an integrating factor and how do you get one?
jenzao
Am I doing this correctly?
Is 2y^4dx +4xy^3dy exact or inexact?
So if its exact, then M(x,y)dx = N(x,y)dy right? (Euler)
But how can I take partial derivative of 2y^4 with respect to x, if there is no x to derive??
thats where I am stuck?
This is unclear.
Unclear
2y^4 is constant does not change with respect to x
If the function f = 2y^4 does not change as x changes; it remains constant
d [f] / dx should be?
You have omitted something here: this is supposed to be
M(x,y) dx + N(x,y) dy = 0
is an exact differential equation (in R) iff
M_y (x,y) = N_x (x,y) everywhere on R.
So you need to take partial derivatives to check this...
... which you have reversed the order of in your work. You should be taking the partial derivative of 2y^4 with respect to y.
No, you have it reversed. It is M(x,y)y= N(x,y)x- assuming you mean M(x,y)dx+ N(x,y)dy.
Then it is a constant with respect to x and the derivative would be 0. However what you want is (2y4)y and (4xy3)x.
Remember WHY you are doing that. IF M(x,y)dx+ N(x,y)dy is an exact differential, then there exist some function f(x,y) such that df= M(x,y)dx+ N(x,y)dy. By the chain rule,
df= \frac{\partial f}{\partial x}dx+ \frac{\partial f}{\partial y} dy[/itex] <br /> so if M(x,y)dx + N(x,y)dy is exact, M(x,y)= f<sub>x</sub> and N(x,y)= f<sub>y</sub>. Taking the derivatives of M and N give the <b>mixed</b> derivatives: M(x,y)<sub>y</sub>= f<sub>xy</sub> and N(x,y)<sub>x</sub>= f<sub>yx</sub>. As long as the derivatives are all continuous, those mixed derivatives must be equal.<br /> <br /> That does NOT answer your title questin &quot;What is the purpose of an integrating factor and how do we find one&quot;. <br /> <br /> Given a function f(x,y), it &quot;differential&quot; is <br /> df= \frac{\partial f}{\partial x}dx+ \frac{\partial f}{\partial y}dy<br /> Writing arbitrary functions for M(x,y) and N(x,y) in M(x,y)dx+ N(x,y)dy may LOOK like a differential but as I pointed out above, such an f exists if and only if the above criterion is satisfied- if and only if the differential is <b>exact</b>. It can be shown that, given anything of the form M(x,y)dx+ N(x,y)dy you can always multiply it by some function of x and y to <b>make</b> it exact- an &quot;integrating factor&quot;. There is, however, NO general method of finding an integrating factor.<br /> <br /> In this particular case, since both M(x,y) and N(x,y) involve only powers of x and y, I might <b>try</b> x<sup>n</sup>y<sup>m</sup> as an integrating factor. Multiplying by that, I have 2x<sup>n</sup>y<sup>m+4</sup>dx+ 4x<sup>n+1</sup>y<sup>m+3</sup>dy. Now, (2x<sup>n</sup>y<sup>m+4</sup>)<sub>y</sub>= 2(m+4)x<sup>n</sup>y<sup>m+3</sup> and (4x<sup>n+1</sup>y<sup>m+3</sup>)<sub>x</sub>= 4(n+1)x<sup>n</sup>y<sup>m+3</sup>. The powers of x and y are correct! In order that those be equal we must have 2(m+4)= 4(n+1) or 2m+ 8= 4n+ 4 so m= 2n- 2. It is easest to take n= 1 so m= 0. That means that x itself is an integrating factor: (2xy<sup>4</sup>)<sub>y[/sup]= 8xy<sup>3</sup> and (4x<sup>2</sup>y<sup>3</sup>)<sub>x<sub>= 8xy<sup>3</sup> also.<br /> <br /> That means there must exist some function f(x,y) so that df= f<sub>x</sub>dx+ f<sub>y</sub>ydy= (2xy<sup>4</sup>)dx+ (4x<sup>2</sup>y<sup>3</sup>)dy. In particular, f<sub>x</sub>= 2xy<sup>4</sup> so, integrating with respect to x (while treating y as a constant since this is a partial derivative) we have f(x,y)= x<sup>2</sup>y<sup>4</sup>+ C(y). Notice that, because y is treated as a constant in <a href="https://www.physicsforums.com/insights/partial-differentiation-without-tears/" class="link link--internal">partial differentiation</a>, the &quot;constant of integration&quot; <b>might</b> be a function of y. However, differentiating that with respect to y we have (x<sup>2</sup>y<sup>4</sup>+ C(y))<sub>y</sub>= 4x<sup>2</sup>y<sup>3</sup>+ C&#039;(y)= 4x<sup>2</sup>y<sup>3</sup> so C&#039;(y)= 0- C really is a constant. f(x,y)= x<sup>2</sup> y<sup>4</sup>+ C.<br /> <br /> Now, whether multiplying by that &quot;integrating factor&quot; disrupts the <b>rest</b> of the problem depends upon what the problem is! dynamicsolo is incorrect to suggest that there <b>must</b> be an &quot;= 0&quot; on that. A &quot;differential&quot; is <b>not</b> a &quot;differential equation&quot; and an &quot;exact differential is not an &quot;exact differential equation&quot;. However, if the problem really were, as he suggested, to solve the (non-exact) differential equation 2y<sup>4</sup>dx+ 4xy<sup>3</sup>= 0, then multiply both sides by x gives 2xy<sup>4</sup>dx+ 4x<sup>2</sup>y<sup>3</sup>= d(x<sup>2</sup>y<sup>4</sup>)= 0 which has the general solution x<sup>2</sup>y<sup>4</sup>= C.</sub></sub></sub>
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
