What is scalar voltage potential with phase shift means?
The discussion centers on the interpretation of the scalar voltage potential represented by the expression V_out=4e^{j\frac {\pi}{6}}. This notation indicates a magnitude of 4 and a phase shift of 30 degrees, derived from the conversion to rectangular form as 4(0.866+j0.5). The phase shift signifies a time-dependent relationship between the output and input voltages. Participants question whether the phase shift implies a change over time and whether only the real part of the expression is relevant for practical applications. Understanding these concepts is crucial for analyzing AC circuits and their behavior.
yungman
Say ##V_{out}=4e^{j\frac {\pi}{6}}##, what is this mean? It is a scalar voltage.
Does this means:
4e^{j\frac {\pi}{6}}=4\left(\cos \frac {\pi}{6}+j\sin \frac {\pi}{6}\right) = 4(0.866+j0.5) = 3.4641+j2=4\angle 30^o
What is the phase shift means, reference to input?
Thanks
Is it changing in time? Maybe it is assumed that you are supposed to take the real part.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
