What is the acceleration due to gravity on planet x based on the range formula?
The acceleration due to gravity on planet X is calculated to be 7.64 m/s² based on the range formula for projectile motion. The discussion highlights the use of two different range formulas: R1 = Vo² sin(2θ)/g and R2 = Vo² sin(2θ)/2g, with the latter providing the correct results for the given conditions. The initial velocity (Vo) was determined to be 46.1 m/s when hitting a golf ball 200 meters at a 23-degree launch angle. The confusion arose from the applicability of the formulas under different circumstances.
  • Understanding of projectile motion and range formulas
  • Familiarity with trigonometric functions, specifically sine
  • Basic knowledge of kinematics and gravitational acceleration
  • Ability to perform algebraic manipulations for solving equations
  • Study the derivation of the range formula R = Vo² sin(2θ)/g
  • Learn about the impact of launch angle on projectile distance
  • Investigate the differences between theoretical and experimental projectile motion
  • Explore the effects of varying gravitational acceleration on projectile trajectories
Physics students, educators, and anyone interested in understanding projectile motion and gravitational effects on different celestial bodies.
Northbysouth
On Earth you are able to consistently hit a golf ball 156 meter when you use your 5 iron which launches the ball at a 23 angle with respect to the ground. If you were to perform this same shot on the surface of an unknown planet called x, and be able to hit the ball 200 m, what will be the acceleration due to gravity on the surface of the planet x?
My confusion is that I have somehow ended up with three range formulas and I don't know what the difference between them is:
R1 = Vo2 sin(2θ)/g
R2 = Vo2 sin(2θ)/2g
I also have my textbook saying:
h = Vo2 sin2(2θ)/2g
Vo = initial velocity
156 meters = V2osin(46)/(2*9.8)
Vo = 65.1964 m/s
Then solving for g on planet x I get the answer as 7.644 which is the correct answer.
What confuses me is the difference between the formulas. Are two of them wrong or are they applicable in different circumstances?
Yes, but using that formula does not give me the correct answer.
I'm confused, if you are able to hit a ball the same distance with the same stroke on two different planets, wouldn't that mean that gravity was the same on each?
That's because I forgot part of the question. On planet X when you hit the ball it goes 200 m.
Sorry, 'll go back and edit the question.
Ah okay :)
You said that you get the correct answer when you use the formula with a ##2g## in the denominator instead of just ##g##, and when you use the ##g## formula you get it wrong.
But when you use the formula with just a ##g##, did you recalculate your ##V_o##?
I ran the calculations again and you're right. I must've confused myself and used the wrong numbers somewhere. Thanks :)
So I get
R=Vo^2 sin(2a)/g
156 m= Vo^2 sin(46)/9.8
Vo = 46.1 m/s
200 m = 46.1^2sin(46)/g
g = 7.64 m/s^2
