What is the acceleration of a particle at t=3s?
  • Thread starter Thread starter markow202
    Course Dynamics
markow202
Im trying to figure out in this question what to do and how to put the formula together.
"A particle travels in a straight line such that for a short time
2s < t < 6s its motion is described by v=(4/a) ft/s, where a is in ft/s^2. If v=6ft/s when t=2s, determine the particle's acceleration when t=3s."
I figured to use a= dv/dt formula but not sure.
If anyone can help...
Yeah, dv/dt will give you the acceleration. But I`m a bit confused about the question. What is the 'a' in your velocity equation? It has the units of acceleration, but it's at the bottom, so whatever the physical quantity the 4 is must have dimension ft^2/s^3. Did you copy the problem correctly?
As its stands, it looks like the velocity does not even depend on time...
Im confused as well about that. I got that equation from the examples in the text.
examples says: "knowing v=f(t) the acceleration is determined from a=dv/dt, since equation relates a,v and t."
When I use this dv/dt formula, which numbers do I divide exactly?
Yeah, the acceleration a is the rate of change (i.e. the time derivative) of the velocity. The derivative dv/dt is not simply a ratio between two numbers.
By the way, this really does not belong in the advanced physics threads.
Not sure where it belonged...
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
