What is the acceleration of the block on the incline?
The acceleration of a block on a frictionless incline is determined by the equation - (g*sin(θ) - T/m), where g is the acceleration due to gravity, θ is the incline angle, and T is the tension in the rope. In this discussion, a mass of 16.0 kg is pulled with a tension of 56.0 N up an incline of 38.0°. The work done by tension before reaching the incline is calculated as 366.27 J, while the work done by friction on a horizontal surface is -182.39 J. The speed of the block before ascending the incline is approximately 4.79 m/s.
  • Understanding of Newton's laws of motion
  • Knowledge of work-energy principles
  • Familiarity with trigonometric functions in physics
  • Basic concepts of friction and tension in mechanics
  • Calculate the net force acting on the block on the incline
  • Learn about the effects of different coefficients of friction on motion
  • Explore the concept of normal force in inclined planes
  • Study the work-energy theorem in more complex systems
Students studying physics, particularly those focusing on mechanics, as well as educators looking for practical examples of forces on inclined planes.
venceslau
A mass m = 16.0 kg is pulled along a horizontal floor, with a coefficient of kinetic friction μk = 0.14, for a distance d = 8.3 m. Then the mass is continued to be pulled up a frictionless incline that makes an angle θ = 38.0° with the horizontal. The entire time the massless rope used to pull the block is pulled parallel to the incline at an angle of θ = 38.0° (thus on the incline it is parallel to the surface) and has a tension T = 56.0 N.
2. The attempt at a solution
1) What is the work done by tension before the block gets to the incline?
T*cos(rad(theta))*d = 366.267398276404 J
2) What is the work done by friction as the block slides on the flat horizontal surface?
-muk*m*g*d = -182.38752 J
3) What is the speed of the block right before it begins to travel up the incline?
sqrt(2*(366.267+(-182.38))/m) = 4.79435866409679 m/s
4) How far up the incline does the block travel before coming to rest?
I have tried everything I can think of, but I keep getting it wrong...
5) What is the work done by gravity as it comes to rest?
This question depends on 4 if I'm not mistaken, so haven't been able to do it yet...
OK.
Careful. Friction = μN. Since the rope is pulling up on the block, the normal force is not simply mg.
You'll need to redo this one.
What's the acceleration of the block when it's on the incline?
Doc Al, thanks for your prompt reply!
This is an online system, and it only took the answer as being correct once I excluded the Y component of the Tension. But I agree with you, it should be factored in there. All the equations I presented above, have already been accepted by the system.
Acceleration of the block on the incline:
-(g*sin(theta) - T/m) ...?
Edit: I finally got it, thanks for the push Doc Al, that was the question I needed asked! :D
  • · Replies 27 ·
11K
