What is the Best Expression for the Acceleration of a Moving Particle?
The best expression for the acceleration of a moving particle, given the position-time graph, is option (D) a = p - qt. This conclusion is supported by the analysis of the second derivative, which indicates that acceleration starts positive and ends negative. The discussion clarifies that the inflection point is characterized by a change in curvature, not by the velocity being zero. The integration of the acceleration expression leads to a velocity equation that confirms the behavior of the particle at the inflection points.
  • Understanding of basic calculus, specifically derivatives and integrals.
  • Familiarity with the concepts of acceleration, velocity, and inflection points.
  • Knowledge of quadratic equations and their roots.
  • Ability to interpret position-time graphs and their derivatives.
  • Study the properties of inflection points in calculus.
  • Learn about the relationship between acceleration, velocity, and position in motion analysis.
  • Explore quadratic equations and their applications in physics.
  • Investigate the implications of the second derivative test for concavity and acceleration.
Students studying physics or calculus, educators teaching motion dynamics, and anyone interested in the mathematical analysis of particle motion.
dk_ch
The accompanying graph of position x versus time t represents the motion of a particle. If p and q are both
positive constants, the expression that best describes the acceleration  of the particle is
(A) a = – - p -– qt (B) a = –p + qt (C) a = p + qt (D) a = p –- qt
In a given solution (D) is the correct answer.
But if we integrate the differential eq obtained from a = p-qt , we get velocity v = pt -0.5qt^2+c
the value of v ie dx/dt =0 for the inflexion pts on x vs t curve and we can get two values of t of the quadratic equation qt^2 -2pt -2c =0 but this gives one negative value of t which is impossible.
Then is (D) option correct? what is my wrong approach ?[/B]
The acceleration is zero at the inflection point, not the velocity.
Chet
Chet
the plot was x-t . why not v=dx/dt = 0 at inflection pts?
An inflection point is one in which the second derivative is zero. On an x-t plot, the velocity is maximum (or minimum) at an inflection point. Take a look at the x vs t plot. Does it really look to you like dx/dt = 0 at the inflection point?
Chet
Because that is not the definition of an inflection point but that of a local extrema. The definition of an inflection point is that the curvature changes sign. This means that the second derivative should be zero and that the lowest non-vanishing derivative after that must be an odd derivative (ie, third derivative, fifth derivative, etc). But back to your actual question.
Normalizing with q = 1, we would get
t = p \pm \sqrt{p^2 + c}.
This does not mean that one of the roots is negative. If you look at your graph again, what is the sign of c? (First of all: What is the interpretation of c?)
Actually I mean stationary inflection pts where first derivative is zero and in the graph there are two points where dx/dt is zero.. if t =0 then c = v ,at t=0, dx/dt is negative,hence c also. THANKS ALL for help.
Well, you do not have any saddle points in the graph ... What you have is a minimum and a maximum, i.e., just two stationary points.
Back to the c issue. What does c describe? (Hint: What happens in your equations when t = 0?)
You can answer in a more qualitative way. You can see from the graph that the second derivative is positive in the beginning (concave upwards) and negative in the end.
This means acceleration starting positive and ending negative. Only one answer satisfies this.
thanks
thanks
  • · Replies 23 ·
  • · Replies 40 ·
