What is the charge carrier density in the conductor
uofcphysics
The Hall voltage across a 0.800-mm-thick conductor in a 1.30 T magnetic field is 3.2 uV when the current is 12.0 A.
What is the charge carrier denisty in the conductor (in m-3).
I was using the equation Vh=IB/ned
where Vh is the Hall voltage
I is the current
B is the magnetic field
n is the charge-carrier density
e is the charge of an electron
and d is the thickness
I rearranged to get n=IB/Vhed
and evaluated to get 3.806*1025m-3
But this came up wrong on the assignment and it looks like an unreasonable answer. I think I need additional values but basically this entire question is really confusing me.
Thanks for the help!
Please show us what numbers you used, and try to keep everything in SI units. Because I get a different answer than you when plugging in the numbers you gave.
I used the numbers I provided so:
I=12.0 A
B= 1.3 T
e= 1.6*10^(-19) C
V= 3.2*10^(-6) V
d= 0.8 mm (I left it because those are the units that the answer is in- but I'm guessing now that that is probably wrong).
What did I miss that is wrong in the calculation?
The units the answer is in is meters, not millimeters. So d = 8*10^-4 m.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
