What is the correct derivative of sin 5x?
  • Thread starter Thread starter bobsmith76
    Derivative Sin
bobsmith76
what is the derivative of sin 5x
using the product rule, i think the answer would be
cos 5x + sin 5
but the book says the answer is 5 cos 5x
cos 5x + sin 5
Take the derivative of sin(x) = cos(x), then take derivative (using power rule) of the inside.
So, derivative of 5x = 5.
Thus, derivative of sin(anything) = cos(anything) * derivative of anything.
Differenciating Sin and Cos is very easy. (It gets trickier with the more complicated trig functions, like Tan). The way I like to remember it, is as follows:
Sin(x)
Cos(x)
-Sin(x)
-Cos(x)
When you differenciate one of these functions, you simply move down the tower to the next function. When you differenciate -Cos(x), you go back up to Sin(x). Except in this case, as you have (5x) inside the brackets, not just (x). So as you're differenciating, you change the Sin(5x) to Cos(5x) and then multiply by the differential of what's inside the brackets. Here, 5x is inside the brackets, the differencial of which is 5. So you multiply by 5. Hence; 5 Cos(5x).
\frac{d}{dx}sin(5x)
Chain Rule:
Derivative of inner function times the derivative of the outer function.
f(g(x)) = f'(g(x))g'(x)
Since
g'(x) = \frac{d}{dx}5x = 5
And
f'(x) = cos(5x)
Thus:
5cos(5x)
cos 5x + sin 5
You are looking at this as the product of what two quantities ?
I see the mistake I was making. As Sammy pointed out I wrongly thought that cos 5x is two quantities when it's not.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
