What is the current through a second separate wire?
  • Thread starter Thread starter TekuConcept
    Current Wire
The discussion revolves around determining the induced current (I2) in a second wire placed parallel to a first wire carrying a current (I1 = 2 amps). The initial formulas mentioned include calculating the magnetic field (B) and the relationship between primary and secondary currents in transformers, but the user is unsure how to apply these concepts without a core. Clarification is provided that stationary or direct current (DC) does not induce voltage, emphasizing the need for changing magnetic flux. The conversation also touches on Faraday's Law of Induction and the Maxwell-Faraday equation, highlighting the importance of time-varying magnetic fields for inducing current. Ultimately, the user seeks to confirm their understanding of the necessary calculations to find the induced current.
TekuConcept
I have two wires, each 1 meter in length. They are at a parallel distances (d) of 5cm from each other.
I send a current through one wire: I1 = 2 amps, and what I want to find is the current induced on the other wire: I2 = ?
I can find B with the following formula (given a radius - which I could substitute with d):
B = μ0I/2πr
For a transformer, I could find I2 using the following formula:
Ip = Is(Ns / Np)
(Where Ip is the primary current, Is is the secondary current, Ns is the number of loops for the secondary coil, and Np the number of loops for the primary coil) However, the transformers I know, all use a core of some sort - which will stretch the magnetic field.
Through my hours of searching, I have come across this formula: ΔF = ΔL(μ0 I1 I2 / 2 π d). I could solve for I2 but ΔF is still unknown here - I guess I could ask 'How do I find ΔF?,' never the less, perhaps there is yet another formula I'm missing out on?
I would like to know of a formula such as: I = f(B, v) where B is a force from say a permanent magnet, moving at a constant speed of v.
B = μ0I/2πr
Ip = Is(Ns / Np)
Welcome to the PF.
Your post is a bit confusing. You at first ask about just 2 parallel wires. In that case, there is no induced current in the 2nd wire. But then you ask about current loops, where there would be an induced voltage and current. Can you please describe the geometry in more detail?
Visualizations Are In Order
Ah, yes... here are pictures and other references to help demonstrate:
Here is the first picture to help visualize what I described in the beginning (basically if I were to create an electromagnetic coil with a driver nail as the inductor's core):
Here is the second picture demonstrating my main objective (given a magnetic force [ B ], relative speed [m/s], relative distance [d], and time [Δt], find the induced current of the wire ):
As a visual demonstration, here is a YouTube clip on 'Magnetic Induction'
Faraday's Law of Induction may be what I am looking for - using the Maxwell-Faraday equation:
∇ x E = -(∂B / ∂T)
(I am only just starting to re-learn all that goes with ∇ again - ie: gradient, divergence, & curl - so I can't determine if I found my answer just yet)
OK so the second wire ISNT the return wire for the first one
that's what we wanted to clarify :)
Dave
Here is the second picture demonstrating my main objective (given a magnetic force [ B ], relative speed [m/s], relative distance [d], and time [Δt], find the induced current of the wire ):As a visual demonstration, here is a YouTube clip on 'Magnetic Induction'Faraday's Law of Induction may be what I am looking for - using the Maxwell-Faraday equation:
∇ x E = -(∂B / ∂T)
This is the vital relationship. The magnetic flux, linking the circuit must be changing with time. Stationary or DC won't induce any voltage. Why not just go to Wiki and see what they have to say about electromagnetic induction? (Note the Counterexample in the Wiki page, though)
Be careful about that YouTube video. Electrons are not the slightest bit like the way they're shown. Just stick to 'Current' if you can .
Yes, I know stationary and DC sources won't induce any voltage - my design is really a spinning motor-generator (similar to those used in the old Lego Mindstorms), and yes I did read the Wikipedia article: 'electromagnetic induction' before sharing the above images and duly noted the counter examples near the bottom - I reference the Maxewell-Faraday equation because of it's accuracy. (non the less, thank you for your suggestion)
I haven't yet figured out how curl (∇ x E) works in vector calculus, but are you suggesting I found my answer already?
(just want to confirm - solve for B which includes distance, then solve the partial derivative given change in time, which should yield the curl of the induced current)
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
