What is the Degree of a Bezier Spline?
  • Thread starter Thread starter Asuralm
    Degree
The degree of a Bezier spline is determined by its differentiability; if a spline is n-differentiable, its degree is n, not n-1. A degree 1 spline is a linear function, while degree 2 and degree 3 splines are quadratic and cubic, respectively, with increasing levels of continuity in their derivatives at the knots. The discussion also touches on the relationship between spline degree and the subdivision matrix S, indicating a need for further clarification on this connection. Understanding these concepts is crucial for effectively utilizing splines in computational applications. Overall, the degree of a spline directly impacts its mathematical properties and behavior.
Asuralm
Spline degree??
Dear all:
I have been read a few definition of the degree of a bezier spline. But I still do not understand what's the exact meaning of it. As I understand, if the spline function is n-differentiable then it's of degree n-1. Is this correct? Another way is that if the control point position is determined by n neighbours of the previous level then the spline curve is of degree n-1.
Am I understanding correct?
Could anyone give me some more straight-forward and easy understandable explanations please?
Thanks
Mathematics news on Phys.org
If the spline is n-differentiable isn't the degree n+1, not n-1?
I may be thinking of a different "degree". A spline is a piece-wise polynomial such that a certain number of derivatives are continuous. Of course, that depends completely upon the degree of the polynomial since the higher degree gives you more constants to match. A "degree 1" spline is a "broken line" that is continuous but not differentiable at all. A "degree 2" spline is a piecewise quadratic function that is continuous and has continuous derivative at the knots but not second derivative. A "degree-3" (cubic) spline is piecwise cubic, having continuous second derivative at the knots.
Yes you are right. It's quite helpful. Thank you.
But another problem is what's the relation between the degree of the spline with the subdivision matrix S?
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
