What is the derivative for x^2 + y^2 + ln(2) = xy?
  • Thread starter Thread starter antinerd
    Derivative
antinerd
Find dy/dx in terms of x and y
I'm pretty sure I did it right, but I am wondering if I was supposed to take the derivative of everything:
2x + 2y = 1
Is that the correct derivative? If so, then I'm good to go...
ln(2) and xy can be derived as well
Didn't I already derive xy? It's 1 right?
And isn't ln(2) a constant?
xy = product rule ... are you doing implicit/explicit differentiation? y' if you are.
ln(2) ... i forgot, been a while since I've taken Calculus
It just says: "Find dy/dx"
So, OK, let me correct the dy/dx xy:
so it's y + x
Now, can the answer be written thus:
x + y = 1 ??
And would I have to write it like this:
dy/dx x+y = 1 dy/dx
so it's y + x
x + y = 1 ??
dy/dx x+y = 1 dy/dx
Where is this "1" coming from? And that still isn't the correct derivative of xy, you need to use the product rule. What is the derivative of y with respect to x?
have you learned the product rule?
f(x)g(x) = f'(x)g(x) + g'(x)f(x)
You need to take partial derivatives, and in the process of doing this, you will get dy/dx 's in your equation. Then group like terms and solve for dy/dx. Have you learned about partial derivatives? The product rule mention above will be helpful in the process, as well.
Alright hold up.
I'd imagine this problm is showing up in the context of a calulus one class after a lesson on implicit differentiation, hence the original poster has probably never encountered partial derivatives before, and has no reason at all to find them for this problem, I don't understand why you think he needs to take partial derivatives.
Crap, you're right, I made a typo. I meant to type implicit, not partial. Apologies.
Not to be nitpicky, but I think what rocophysics meant was
(fg)'(x)=f'(x)g(x) + g'(x)f(x)
I don't go looking to correct peoples' mistakes, however I know how difficult learning new notations can be. If we all start out on the same page, it will be easier down the road.
Casey
The thing that I'm not getting is how to get from
2x + 2y + ln2 = xy
to
d/dx (2x + 2y + ln2) = xy
and what to do after that, and what to do with the other side of the equation...
Can someone show me a small example of how to do these derivatives?
If you take the derivative with respect to x of the left hand side of the equation, you have to take it of the right hand side, too.
However, simply writing d/dx on the left side there isn't enough. You need to take the derivative with respect to x to each of the summands on the left side (and, of course, the right side of the equation too).
For instance, the derivative w.r.t. x of 5x^3 would be 15x^2(\frac{dx}{dx})=15x^2.
The derivative w.r.t. x of 4y^3, however would be 12y^2(\frac{dx}{dy}). The \frac{dx}{dy} remains in this case.
You have learned about implicit differentiation, correct?
2x + 2y + ln2 = xy
to
Let's start over. You are being asked to implicitly differentiate the function
x^2+y^2+ln(2)=xy
Now how about an easier one to start. Can you try to implicitly differentiate
x^2+y^2=1 with respect to x?
You want d/dx(x^2 + y^2 + ln(2)) = d/dx(xy). Split this into four derivatives and I'm sure anyone here will jump on anyone you get wrong.
For instance, the derivative w.r.t. x of 5x^3 would be 15x^2(dx/dx)=15x^2.
The derivative w.r.t. x of 4y^3, however would be 12y^2(dy/dx). The dy/dx remains in this case.
Yeah, I have. But I suck at life.
So what about this for starters:
d/dx (x^2 + y^2 + ln2) = (xy) d/dx
would I then do:
2 + 2y (d/dx) + 0 = xy d/dx
x^2+y^2+ln(2)=xy
x^2+y^2=1
2x + y^2 = 1
And what about finding dy/dx in terms of x AND y?
antinerd said:
x^2+y^2=1
2x + y^2 = 1
2x is good.
Now what about y^2? what happened to its derivative? Apply the power rule nx^{n-1} and then we'll apply the chain rule.
Also what is the derivative of a constant (1)?
Remember that when differentiating implicitly, we are differentiaiting the ENTIRE function with respect to x.
Casey
no prob, I'm picky as well
Saladsamurai said:
2x is good.
But if it's with RESPECT to x, don't you just derive the terms with x?
But to answer your question, it's:
2x + 2y = 0
correct?
2x + 2y = 0
correct?
No that is not true, you're forgetting the chain rule. What is the derivative of y2 if y is a function of x?
Remember that d/dx (y) = dy/dx
To take the derivative of y^3 for example you use the chain rule...
\frac{d}{dx}(y^3) = \frac{d}{dy}(y^3) * \frac{dy}{dx} = 3y^2 * \frac{dy}{dx}
Example of product rule...
\frac{d}{dx}(x^3y^2) = <br /> (\frac{d}{dx}(x^3))(y^2) + (x^3)(\frac{d}{dx}(y^2))<br /> =3x^2y^2 + x^3(2y*\frac{dy}{dx})<br /> =3x^2y^2 + 2x^3y*\frac{dy}{dx}
correct?
No because everything except the constant varies with x. if you wanted you could rewrite the equation EXPLICITLY in terms of y to get y=sqrt(1-x^2) and then take the derivative...but we want to do it IMPLICITLY.
WRT x means "as x changes), not just the terms involving x 'matter'
2x + 2y = 0
correct?
You are close, but we want the derivative of y^2 wrt x, so we need to apply the chain rule. Do you know the chain rule d/dx [u^2]=2u*du/dx
So in the case of y^2 it is 2y times the derivative of y wrt x ...and that is just dy/dx
Are you sure you wrote that down correctly?
Because x^2 + y^2 + \ln 2 = xy has no real solutions...
*Proof: Assume x,y \in \mathbb{R}
then x^2 + y^2 + \ln 2 = xy \Rightarrow x^2 + y^2 &lt; xy
>However, since x=y \vee x \ne y,
\begin{gathered}<br /> {\text{1)}}\;x = y \Rightarrow x^2 + y^2 &lt; xy \Leftrightarrow 2x^2 &lt; x^2 ,\;{\text{which}}\;{\text{is a contradiction}} \hfill \\<br /> {\text{2)}}\;x \ne y \Rightarrow \left| x \right| &lt; \left| y \right| \vee \left| x \right| &gt; \left| y \right| \hfill \\<br /> {\text{ }}\left| x \right| &lt; \left| y \right| \Rightarrow xy &lt; y^2 \Rightarrow xy &lt; x^2 + y^2 \hfill \\<br /> {\text{ }}\left| x \right| &gt; \left| y \right| \Rightarrow x^2 &gt; xy \Rightarrow x^2 + y^2 &gt; xy \hfill \\<br /> {\text{ Both of these contradict }}x^2 + y^2 &lt; xy \hfill \\ <br /> \end{gathered}
then x^2 + y^2 + \ln 2 = xy \Rightarrow 0 \leqslant x^2 + y^2 &lt; xy \Rightarrow 0 &lt; xy
\begin{gathered}<br /> {\text{1)}}\;x = y \Rightarrow x^2 + y^2 &lt; xy \Leftrightarrow 2x^2 &lt; x^2 ,\;{\text{which}}\;{\text{is a contradiction}} \hfill \\<br /> {\text{2)}}\;x \ne y \Rightarrow \left| x \right| &lt; \left| y \right| \vee \left| x \right| &gt; \left| y \right| \hfill \\<br /> {\text{ }}\left| x \right| &lt; \left| y \right| \Rightarrow \left| {xy} \right| &lt; y^2 \Rightarrow \left| {xy} \right| &lt; x^2 + y^2 \Rightarrow xy &lt; x^2 + y^2 \because xy &gt; 0 \hfill \\<br /> {\text{ }}\left| x \right| &gt; \left| y \right| \Rightarrow x^2 &gt; \left| {xy} \right| \Rightarrow x^2 + y^2 &gt; \left| {xy} \right| \Rightarrow x^2 + y^2 &gt; xy\because xy &gt; 0 \hfill \\<br /> {\text{ Both of these contradict }}x^2 + y^2 &lt; xy \hfill \\ <br /> \end{gathered}
Good point! I guess we can assume x and y are complex... :confused: I don't think it affects the implicit differentiation does it?
bomba923 said:
Am I the only one who found this strange?
Yeah, well, that's the question that's written down...
Hmm... I guess it doesn't really matter. Does it even affect what I will get as a derivative?
  • #31
How can I use the chain rule here?
  • #32
See post #25.
  • #33
All real numbers are complex; perhaps you meant, "assume x or y have nonzero imaginary coefficients?"
You can still implicitly differentiate 'y' with respect to 'x' in x^2 + y^2 + \ln 2 = xy
to obtain
y&#039; = \frac{{2x - y}}{{x - 2y}}
with simple poles spanning the (complex) line x = 2y as expected
There is not much difference if you set your domain to be \mathbb{C}^2 - \mathbb{R}^2;
otherwise your original equation cannot solve your derivative (i.e, with domain \mathbb{R}^2)
  • #34
OK so, guys, I just want to thank you for the help so far :)
This is getting the dx/dy with respect to x and y, correct?
x^2 + y^2 + ln2 = xy
(d/dx) x2 + (d/dx) y^2 + (d/dx) ln2 = (d/dx) xy
2x + 2y dy/dx + 0 = y + x dy/dx
Is this correct so far? If not, what am I doing wrong? I would appreciate corrections :)
  • #35
You're writing things like (dy/dx)y^2 when you should be writing (d/dx)y^2.
The first is multipying a function dy/dx by another function y^2, the second is applying the derivative operator d/dx to the function y^2, which is what you should be doing.
  • #36
That is correct. Now solve for dy/dx.
  • #37
That's where I need the help... :(
Is it now just algebraic manipulation, or do I have to do something with the terms:
2y (dy/dx) and x (dy/dx)
  • #38
It is just algebraic manipulation. The calculus is over. Move both terms to one side of the equation and factor out dy/dx.
  • #39
You're the man, Dick!
Thanks to everyone.
Final answer:
dy/dx = (-x+1) / y
PLEASE TELL ME THIS IS CORRECT! THEN I CAN BLOW THROUGH THE REST OF 'EM!
  • #40
Thanks to everyone.
Final answer:
dy/dx = (-x+1) / y
I'm getting dy/dx = (y-2x)/(2y-x)
check your algebra.
  • #41
check your algebra.
Wait I got
(2x-y)/(x-2y) = dy/dx
  • #42
Because isn't it:
(2x-y) = dy/dx (x-2y)
and then you divide to get dy/dx = (2x-y)/(x-2y)
  • #43
antinerd said:
Because isn't it:
same thing. :smile: (if I multiply the numerator and denominator by -1, I'll get it that way)...
I took the dy/dx to the left side when solving, you took it to the right... it's the same answer.
  • #44
Pffsh. Equations don't have derivatives. Implicit functions do, however.
  • #45
Your mom has derivatives.
  • #46
Don't be confused by the title of this thread
Rest assured no one was trying to "differentiate an equation" :wink:
