What is the Derivative of P/T with respect to T?
  • Thread starter Thread starter IngridR
    Coefficient Joule
IngridR
Hi, i have a little problem with a demostration, I hope you can help me.
this said that we have a system, a gas is containing in a recipe, there's no heat exchange neither work with the enviroment, only an expansion v to 2v, we have to find that
(dT/dv)u=-(T^2/Cv)(d/dT)(P/T)v
I start with
dU=(dU/dT)vdT+(dU/dv)t dU=0
(dT/dv)u=-(dU/dv)(dT/dU)vdv
(dT/du)v=1/Cv
(dT/du)=-(1/cv)(T(dP/dT)-P)
I don't know how continue!
Welcome to PF;
Have I understood you correctly:
An ideal(?) gas in a container (recipe?!), no heat may enter or leave the container(?), and no work is done on or by the gas(?) ... yet there is an expansion? How can this be?
It sounds like you are trying to describe an adiabatic expansion.
Simon Bridge said:
Welcome to PF;
yes! Sorry i have some problems lol! In fact it's a free expansion U=0 Q=0 and w=0
A free expansion
I try to find the Joule coefficient (dT/dv) constant U.
I must find that it's equal to -(T^2/Cv)d/dT(P/T) constant V, but
I found that it's equal to (-1/Cv)(T(dP/dT)v-P)
Oh you mean - like in the title ?!
All right: you got
$$\left.\frac{dT}{dv}\right|_U = -\frac{1}{C_v}\left(T\left.\frac{dP}{dT}\right|_v -P \right)$$
You need to get from there to:$$\left.\frac{dT}{dv}\right|_U = -\frac{T^2}{C_v}\left. \frac{d}{dT}\frac{P}{T}\right|_v$$
... it looks like you are almost there since you expression rearranges as:
$$\left.\frac{dT}{dv}\right|_U = -\frac{T^2}{C_v}\left(\frac{1}{T}\left.\frac{dP}{dT}\right|_v -\frac{P}{T^2} \right)$$
So what is $$\frac{d}{dT}\frac{P}{T}$$
Likes 1 person
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
