Undergrad What is the difference between types of expansions?
The discussion clarifies the differences between three types of gas expansions: Joule's (free) expansion, adiabatic expansion, and Joule-Thomson expansion. Joule's expansion occurs when gas expands into a vacuum in a thermally isolated container, while Joule-Thomson expansion involves gas passing through a valve in a similar setup. Both Joule's and Joule-Thomson expansions are irreversible processes, categorized under adiabatic expansions, which are thermally isolated. An example of adiabatic expansion not fitting these types is gas expanding in a cylinder by pushing a piston, which may be reversible. The nuances of these processes highlight the complexities of thermodynamic behavior in isolated systems.
Gopal Mailpalli
Can someone differentiate between differet types of expansion,
  1. Joule's expansion (free expansion)
  2. Adiabatic expansion
  3. Joule - Thomson or Joule - Kelvin expansion
I think that 1 and 3 are both specific types of 2, as both are defined to be adiabatic - which just means thermally isolated.
Type 1 is when a thermally-isolated container is divided into two parts separated by an openable divider, with one part containing gas and the other a vacuum, and the divider is then opened, to allow the gas to expand into the vacuum part.
Type 3 is a more complicated process (explained here) where a gas is forced through a valve or porous plug, and the system where this happens is thermally isolated.
Both 1 and 3 are irreversible processes.
An example of an adiabatic expansion that is neither type 1 or 2 would be where the gas in a cylinder expands by pushing back a piston, while remaining thermally isolated. I think (but am not sure) that that would be a reversible process.
An adiabatic expansion involving a piston and cylinder is not necessarily reversible.
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
