What Is the Final Vertical Velocity Component of the Ball?
The discussion revolves around determining the final vertical velocity component of a ball after it collides with a vertical wall. The ball has an initial velocity and is subjected to a horizontal force from the wall, while gravity also acts on it.
  • Mixed
  • Participants explore the effects of gravity on the vertical velocity component and question how to calculate the change in vertical velocity during the collision. There are discussions about the time of interaction with the wall and how it relates to the vertical forces acting on the ball.
Participants have provided various insights into the problem, including the role of gravity and the need to consider vertical forces. Some have expressed confusion regarding the correct formulas to use for finding the final vertical velocity component, while others have suggested that gravity should not be ignored in the analysis.
There is uncertainty regarding the assumptions of the problem, particularly whether gravity is to be considered in the context of the collision and how it affects the vertical velocity component. The wording of the problem has also been questioned, leading to differing interpretations among participants.
scbeturner
1. A 0.20kg ball with an initial velocity of (26i-1.6j)m/s collides with a vertical wall. The wall exerts a constant force of -175i N on the ball and the ball's final horizontal velocity component is -15i m/s. Find the final vertical velocity component of the ball.
2. I know how to find the total change in momentum of the ball and how long the ball was in contact with the wall, but i don't know how to find the vertical velocity component.
3.
What vertical force acts on the ball? ehild
I am guessing gravity maybe?
Yes, it is gravity. Gravity causes a vertical acceleration. You know the time of interaction with the wall. How much does the vertical velocity component change during that time? ehild
I thought I had to know the final velocity in order to find the interaction time with the wall and would find it using the formula: FΔt=m(v2-v1)...is that right?
It is true for each components separately. The wall exerts horizontal force so it changes the horizontal velocity component. You know both the initial and final horizontal velocity components and you know that the wall exerts a horizontal force of -175i N. How long does this force act on the ball?
Gravity exerts vertical force: it changes the vertical velocity component. You need the time Δt to calculate the vertical change of velocity during the interaction with the wall.
ehild
so would the time be:
-175Δt=.2(-15i-26i)
-175Δt=.2(-41)
-175Δt=-8.2
t=.047?
It is OK, but use one more digits as you will use this number for further calculation. So Δt=0.0469 s.
(And either omit the i-s everywhere or use them everywhere, and do not change Δt to t.)
Now calculate the change of the vertical velocity component because of gravity.
ehild
9.81(.0469)=.2(v2+1.6)
.460089=.2v2+.32
.140089=.2v2
v2=.7004m/s
is that right?
No, it is wrong.
The change of velocity is aΔt.
ehild
I'm confused...what formula do I need to find the final vertical velocity component?
How do you get the velocity of a falling body?
ehild
The motion equation: v(t)=v0+at?
Yes.
ehild
-1.6+(9.81)(.0460)=-1.14
Is that right?
Gravity points downward. Your result is correct if the vertical axis of the coordinate system also points downward. I guess the problem meant upward y axis. Then g=-9.81 m/s^2.
ehild
In my answer key, it says that the final vertical velocity component is -1.6j, which is the same as the initial vertical velocity component. what am I doing wrong?
I think you are correct. If that wall were in the free space, the answer key would be correct: The force of the wall in the x direction changes only the x component of the velocity. But we are on the Earth and everything is exposed to gravity, and it changes the vertical velocity during the time while the wall and ball are in contact.
ehild
In my answer key for this problem it says that the final vertical velocity component is the same as the initial vertical velocity component...is that right?
It depends on the problem, if gravity is supposed to exist or not. Ask your teacher about it. In my opinion, talking about horizontal and vertical, and ignoring gravity at the same time is not correct.
ehild
Alright thanks for all the help!:)
You are welcome. ehild
ehild
Suppose the particle is moving in the x-y plane and g is along the z axis, then?
rl.bhat, have you read the problem? It asks the vertical velocity component after collision. Gravity is vertical. Do you mean that gravity does not act if the ball moves horizontally at the instant of collision? The vertical velocity component will change any way.
ehild
In the given velocity if 'i' component is horizontal component, what is 'j' component?
I do not know. It can be anything. The problem is badly worded. I do not think it has any sense trying to read the mind of the person who wrote this problem.
ehild
  • · Replies 19 ·
  • · Replies 38 ·
