- 15,171
- 3,378
I don't think Healey's third argument is correct. If Alice knows that Dan has recorded a definite outcome, then Dan has collapsed the state. So Eq 23 is not correct. It should be a proper mixture, not a pure state.
martinbn said:I don't understand this. How does 2. imply that there is no ontology other than ##\psi##? In fact, in my opinion, it is an extreme abuse of language to say that ##\psi## is ontology. What does it even mean?
But I still don't understand Demistifier's argument. I don't see how 2. and 4. contradict 1.stevendaryl said:I think that the issue is whether the wave function is subjective--that is, its value reflects the knowledge of the observer--or objective--it has an actual value, even if the observer may not know what that value is.
martinbn said:But I still don't understand Demistifier's argument. I don't see how 2. and 4. contradict 1.
stevendaryl said:... The physical interpretation seems to violate causality (no effects can travel faster than light).
I don't see a satisfactory way out if you accept Bell's proof and you also accept FTL limitations for effects. There are more exotic ways out, and they are Many-Worlds (Bob's result doesn't have a definite value) and superdeterminism, but those are unsatisfactory for other reasons.
stevendaryl said:I'm not sure I understand that specific argument. But EPR-type correlations seem to me to make it difficult to understand how the wave function can be epistemological (if that's the antonym of ontological).
I've stated this simple argument several times before, but I don't know of a good answer to it.
Let's take the case where Alice and Bob are measuring spins of anti-correlated spin-1/2 particles. To make it definite, let's assume that they are both planning to measure spin along the z-axis. Let's pick an inertial coordinate system in which Alice and Bob are both at rest, and assume that Bob is farther from the source of twin particles than Alice, so he measures his particle's spin slightly later than Alice does (although the two measurements have a spacelike separation).
- Immediately before Alice performs her measurement, she would rate the probabilities for Bob's results to be 50/50 spin-up or spin-down.
- Immediately after Alice performs her measurement and gets the result "spin-up", she knows with 100% certainty that Bob will get the result "spin-down".
- So the statement "Bob will get spin-down" goes from being uncertain with 50/50 probability to true.
- So it seems that Bob's situation (as understood by Alice) makes a nearly-instantaneous change.
- There are two different possible interpretations of this sudden change. They are (1) epistemological, or (2) physical. (Maybe there are more than two possibilities, but I don't know of others.) Under the epistemological interpretation, the fact that Bob will get spin-down was true BEFORE Alice performed her measurement, and Alice's measurement simply allowed her to know this. Under the physical interpretation, the fact that Bob will get spin-down wasn't true before Alice performed her measurement, but became true as a side-effect of her measurement.
- The epistemological interpretation seems to be contradicted by Bell's proof.
- The physical interpretation seems to violate causality (no effects can travel faster than light).
1977ub said:Can you articulate or link your favorite reasons why SD is unsatisfactory? Thank you.
stevendaryl said:I'm sorry, what is SD?
I wouldn't say Bell's theorem says anything too strong about the epistemological view. In fact I would say it has the same implications for ontic and epistemic views. It tells you the underlying ontology can't be a non-superdeterministic mathematical* local causal** single world, regardless of whether ##\psi## is part of that ontology or not.stevendaryl said:The epistemological interpretation seems to be contradicted by Bell's proof.
You're assuming an interpretation with some sort of reasonably objective collapse, not that that's wrong, but it doesn't affect Masanes proof.atyy said:I don't think Healey's third argument is correct. If Alice knows that Dan has recorded a definite outcome, then Dan has collapsed the state. So Eq 23 is not correct. It should be a proper mixture, not a pure state.
DarMM said:You're assuming an interpretation with some sort of reasonably objective collapse, not that that's wrong, but it doesn't affect Masanes proof.
Under the kind of Copenhagen advocated by Bohr and others since QM is just a calculus of expectations (in modern terminology a Bayesian framework) from the perspective of Alice you would have:
$$|\uparrow\rangle|d-ready\rangle \rightarrow |\uparrow\rangle|d-up\rangle$$
and
$$|\downarrow\rangle|d-ready\rangle \rightarrow |\downarrow\rangle|d-down\rangle$$
you'd have to have:
$$\sqrt{\frac{1}{2}}\left(|\downarrow\rangle + |\uparrow\rangle\right) |d-ready\rangle \rightarrow \sqrt{\frac{1}{2}}\left(|\uparrow\rangle|d-up\rangle + |\downarrow\rangle|d-down\rangle\right)$$
You're saying it should be a mixed state instead, but that implies you should know for some systems`you have yet to observe you should decide whether to apply unitary evolution or collapse. Would you measure this via decoherence?
It is assumed that there is no objective collapse. It is an update of agent's knowledge. So if Dan subjectively collapsed the state, it doesn't mean that the subjective collapse refers also to Alice. To make an analogy, if Alice knows that Dab thinks that Angelina Jolie is beautiful, it doesn't mean that Angelina Jolie is beautiful from the point of view of Alice.atyy said:I don't think Healey's third argument is correct. If Alice knows that Dan has recorded a definite outcome, then Dan has collapsed the state. So Eq 23 is not correct. It should be a proper mixture, not a pure state.
Demystifier said:It is assumed that there is no objective collapse. It is an update of agent's knowledge. So if Dan subjectively collapsed the state, it doesn't mean that the subjective collapse refers also to Alice. To make an analogy, if Alice knows that Dab thinks that Angelina Jolie is beautiful, it doesn't mean that Angelina Jolie is beautiful from the point of view of Alice.
If my Angelina Jolie counterexample has not convinced you, here is another counterexample: Bohmian mechanics. In BM there is no collapse of the full wave function of the Universe. But BM has a conditional wave function, which does not obey the Schrödinger equation and hence collapses when the measurement is performed. For definiteness, let us model the full wave function asatyy said:But Dan has a definite outcome - to whom? If Alice acknowledges that Dan has a definite outcome, then Alice must collapse the state. If Alice does not acknowledge that Dan has a definite outcome, then there is no definite outcome for Alice, and there is no P(a,b,c,d) for Alice.
Demystifier said:If my Angelina Jolie counterexample has not convinced you, here is another counterexample: Bohmian mechanics. In BM there is no collapse of the full wave function of the Universe. But BM has a conditional wave function, which does not obey the Schrödinger equation and hence collapses when the measurement is performed. For definiteness, let us model the full wave function as
$$\Psi(x,x_A,x_D,t)$$
where ##x## is the position of the measured particle, ##x_A## are positions of particles constituting the Alice's measurement apparatus and ##x_D## are positions of particles constituting the Dan's measurement apparatus. Then the Alice's conditional wave function is
$$\psi_A(x,x_D,t)=\Psi(x,X_A(t),x_D,t)$$
where ##X_A(t)## are the Bohmian trajectories. Similarly, the Dan's conditional wave function is
$$\psi_D(x,x_A,t)=\Psi(x,x_A,X_D(t),t)$$
Clearly, the collapse of ##\psi_D## does not imply the collapse of ##\psi_A##. However, Alice knows that Dan's wave function collapses, so Alice may alternatively use the wave function
$$\psi'_A(x,t)=\Psi(x,X_A(t),X_D(t),t)$$
which does collapse when ##\psi_D## collapses. So which wave function should Alice use? It's up to her. But she must be consistent. A logical contradiction may arise if she mixes conclusions obtained from ##\psi_A## with those obtained from ##\psi'_A##.
In that case, according to BM, there is never collapse for Alice.atyy said:Alice can always just use ##\Psi(x,x_A,x_D,t)##.
Demystifier said:In that case, according to BM, there is never collapse for Alice.
What you fail to realize is that there is no Copenhagen interpretation. There are several different interpretations that people call "Copenhagen". You are referring to one particular version of Copenhagen (say the Landau-Lifshitz version), but the FR-Masanes theorem rules out another version of Copenhagen, a version that denies the objective collapse but accepts objective measurement outcomes. The theorem is not applicable to "your" LL version of Copenhagen.atyy said:OK, but I don't think there is any contradiction to what I wrote in post #103 which was according to Copenhagen.
Demystifier said:What you fail to realize is that there is no Copenhagen interpretation. There are several different interpretations that people call "Copenhagen". You are referring to one particular version of Copenhagen (say the Landau-Lifshitz version), but the FR-Matsas theorem rules out another version of Copenhagen, a version that denies the objective collapse but accepts objective measurement outcomes. The theorem is not applicable to "your" LL version of Copenhagen.
In many-worlds, the worlds are neither non-local nor local. They are alocal: http://de.arxiv.org/abs/1703.08341David Byrden said:Not if you interpret QM in a "many worlds" way, remembering that the "worlds" are local.
Yes, that's what I would like to know too. It seems to me that @vanhees71 believes something like that. If I'm right, it seems that we finally have a theorem against him.atyy said:That's fine. But did anyone believe the FR-Masanes version anyway?
Demystifier said:Yes, that's what I would like to know too. It seems to me that @vanhees71 believes something like that. If I'm right, it seems that we finally have a theorem against him.![]()
I think BM is now his second best interpretation. Maybe when he learns about the FR-Masanes-Leifer theorem it will become his first.atyy said:I thought he converted to BM?![]()
David Byrden said:1. Yes, it is.
2. No, it doesn't. Not if you interpret QM in a "many worlds" way, remembering that the "worlds" are local.
##P(a,b,c,d)## is the "objective" probability of occurrences of outcomes of the experiment, i.e. simply the frequencies that actually occur. It's not the predicted frequencies of outcomes for any particular observer since nobody in the set up can observe all four of ##a,b,c,d##.atyy said:But Dan has a definite outcome - to whom? If Alice acknowledges that Dan has a definite outcome, then Alice must collapse the state. If Alice does not acknowledge that Dan has a definite outcome, then there is no definite outcome for Alice, and there is no P(a,b,c,d) for Alice.
Brukner, Zeilinger, Healey himself, the older Quantum Bayesians (i.e. not QBism). Anybody who thought QM was purely a probability calculus for objective outcomes.atyy said:That's fine. But did anyone believe the FR-Masanes version of Copenhagen anyway?
Alice has no access to ##c## for this reason, but it's not a reason ##P(a,b,c,d)## doesn't exist as it is simply the probability of the outcomes to occur in one run of the experiment, even if nobody has access to all four outcomes.atyy said:In the Healy third argument version of Copenhagen, if we undo the measurement, including the state of the measuring apparatus, then is the record of the measurement outcome lost? In other words, if Alice undoes Carol's "unitary measurement", then is Carol's measurement outcome available to Alice? If it isn't, then this would be another way of saying there is no P(a,b,c,d) for Alice.
However is it irreversible to a superobserver with full control over the observer's environment? That's who performs the reversing, not the observer themselves.atyy said:In Copenhagen QM, a measurement must FAPP be irreversible to the observer, and there is no level beyond FAPP
I genuinely don't understand how the epistemological view of ##\psi## is ruled out by Bell's theorem. I've never seen this expressed in Quantum Foundations papers. The whole motivation of the PBR theorem is to provide constraints on epistemological views when previous theorems didn't, that's what's important about it.David Byrden said:Yes, it is.
DarMM said:##P(a,b,c,d)## is the "objective" probability of occurrences of outcomes of the experiment, i.e. simply the frequencies that actually occur. It's not the predicted frequencies of outcomes for any particular observer since nobody in the set up can observe all four of ##a,b,c,d##.
Plus this is the sticking point for me, how does Alice know when they've a definite outcome? What condition do you use to switch from a pure state to a mixed state if you're not looking at their laboratory? She models Carol's lab under unitary evolution up to what point? Decoherence?
DarMM said:Brukner, Zeilinger, Healey himself, the older Quantum Bayesians (i.e. not QBism). Anybody who thought QM was purely a probability calculus for objective outcomes.
DarMM said:Alice has no access to ##c## for this reason, but it's not a reason ##P(a,b,c,d)## doesn't exist as it is simply the probability of the outcomes to occur in one run of the experiment, even if nobody has access to all four outcomes.
DarMM said:However is it irreversible to a superobserver with full control over the observer's environment? That's who performs the reversing, not the observer themselves.
