What is the fundamental frequency of an aluminum rod?
The discussion revolves around determining the fundamental frequency of a longitudinal standing wave in an aluminum rod. Participants explore the relationship between the speed of sound in the rod and its length, referencing various sources for the speed of sound in aluminum.
  • Exploratory, Assumption checking
  • Participants attempt to apply the formula for frequency based on the speed of sound and the length of the rod. Questions arise regarding the source and accuracy of the speed of sound in aluminum, with some participants suggesting the use of textbooks or specific online resources for reliable values.
There is ongoing exploration of the speed of sound in aluminum, with various values being cited from different sources. Some participants express uncertainty about the accuracy of these values and seek clarification on how to obtain a reliable figure for calculations.
Participants note the importance of using consistent and accurate values for the speed of sound, as discrepancies in sources may lead to different conclusions. The length of the rod is confirmed to be 2 meters, but the method for calculating the speed of sound remains a point of discussion.
mcnealymt
A longitudinal standing wave can be created in a long, thin aluminum rod by stroking the rod with very dry fingers. This is often done as a physics demonstration, creating a high-pitched, very annoying whine. From a wave perspective, the standing wave is equivalent to a sound standing wave in an open-open tube. In particular, both ends of the rod are anti-nodes. (Figure 1)
http://session.masteringphysics.com/problemAsset/1074200/4/knight_Figure_21_55.jpg
I know:
f1= v/2L
The problem is that I don't know how to calculate the speed of sound in an aluminum rod. I've ran across only one similar problem where they used:
f = v / 2 L ; where v = speed of sound
So we need to find the speed of sound in aluminum. See second web site.
f = (4877 m/s) / (2∙1.90m)
f = 128.2 s^-1 = 128.2 Hz
they then used this link to find the speed of sound in a aluminum rod
http://www.engineeringtoolbox.com/sound-speed-solids-d_713.html
ANy ideas?
Hello.
Where did you get that value for the speed of sound in aluminum? It's not the value given in your link.
This information I found on yahoo answers:
How did you get the length of the rod?
The length was given. It is 2m. My question is how do I find the speed of sound in an aluminum rod.
Are you using a textbook? It might have a table of speeds of sound for different materials. You can also calculate the speed from the density and bulk modulus of the material.
http://hyperphysics.phy-astr.gsu.edu/hbase/sound/souspe2.html
[EDIT: From links given by SteamKing in post #10 below, it's Young's modulus and not the bulk modulus that should be used for the speed of sound in thin rods. Sorry for the error.]
Use this equation that you have. "f1= v/2L You know the length. Now if you know the frequency you can find the velocity, and if you know the velocity, from your second link, you can find the frequency.
Does anyone know what the speed of sound in aluminum rod is??!
Why not use the value in your link?
The problem with getting a value from a web search is that different sites will give somewhat different values.
That's why it would be best to get a value from your text if you can find it there.
According to this link: http://www.rfcafe.com/references/general/velocity-sound-media.htm
the speed of sound in an Al rod for long. extensional waves is 5000 m/s
This link: http://www.physics.umd.edu/lecdem/services/demos/demosh1/h1-23.htm
gives similar results.
Good old wiki confirms:
http://en.wikipedia.org/wiki/Speeds_of_sound_of_the_elements_(data_page)
Probably the last word in singing Al rods:
http://www.dougdelamatter.com/website1/science/physics/Longitudinally_Vibrating_Singing_Rod.pdf
17K
11K
