peevemagpie
- 11
- 2
I have not really read anything about the topic until this time. But this is interesting for me. I have to read more on it or is there a video related to this topic?
RonL said:My point was basically that the ocean seems to have this constant motion in any location and that storm affects are only around 30 or 40 meters below surface, as far as I know.
The 1/2 wavelength rule is a good way to think about the physics of the surface waves and their decay with depth. To answer the question of whether the waves will be "felt" inside the submarine (or whether the boat will be significantly affected), one probably also needs to consider the wave amplitude and period, as well as any compounding conditions such as mixed waves, shears, etc.msubby said:The depth the effect of a wave will be felt when inside a submarine is equal to 1/2 the wave length of the wave on the surface. IE if the peak to peak distance of the wave at the surface is 100m, the effect of that wave will be felt down to 50m depth.
FWIW, this is usually a decent approximation, but you commonly see some "peakiness" to the waves as the amplitudes get larger.The wave form of a 'wave' as in as found on the open ocean, is sinusoidal.
msubby said:The inferred query in the original question seemed to be, was the effect of a wave (or wave system) a surface phenomenon or full water column depth phenomenon. The two instances given, being during a hurricane or a Tsunami. The two examples being perfect examples of each event. The Tsunami is a full water column movement (transfer of energy) & a hurricane is a surface movement governed by the sinusoidal rule (with small variations due to mixed wave patterns etc).
We view the waves induced by a hurricane as a superposition of sinusoidal waveforms as a matter of convenience. As I mentioned earlier, deep water waves aren't exactly a superposition of independent sinusoidal waves, but it is an approximation that works very well in many cases.msubby said:What I was saying was the wave type induced by a hurricane is a sinusoidal waveform, at the surface...A wave isn't a single waveform in reality. It is a composite pattern of waveforms overlaid upon each other. Hence the occasional larger than average wave often observed, when the peak of two or more overlaid waveforms synchronize at one location.
Glad to make your acquaintance! It would be cool to hear more about your experiences in submarining.I am a submariner, in mini subs. I have spent thousands of hours in the zone where the effects of the waves above can be felt.
