What is the KE before and after collision?
  • Thread starter Thread starter lish
    Collision
lish
a truck of a mass 2kg travels at 8m/s towards a stationary truck of mass 6kg. after colliding,the trucks link and move off together
A) what is the common velovity?
B) what is the KE before and after collision?
C) explain the apparent loss in energy
Help please :D
For the before portion of the collision of the problem, only the momentum of the truck counts since the stationary truck is not moving. to calculate the common velocity, you know that the two masses are link together, so just sum the two masses. Now that you have your two masses sum together, and the initial velocity of the moving truck, you can easily find the common velocity.
Since you know the initial velocity, you can calculate the initial KE and once you calculate the final common velocity of the linked trucks, you can calculate the final KE of the two trucks.
Help please :D[/QUOTE]
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
