What is the Limit of 3+dx? Understanding Limits in Calculus
  • Context: Undergrad
  • Thread starter Thread starter CuriousBanker
    Limits
The discussion revolves around the concept of limits in calculus, specifically examining the limit of the expression 3+dx, where dx is considered an infinitesimally small quantity. Participants explore the implications of this expression in relation to a function that is undefined at a certain point, and whether a limit exists in this context.
  • One participant asserts that the limit of f(x) as x approaches 3 is 6, despite f(x) being undefined at x=3, and questions the existence of the limit of 3+dx.
  • Another participant suggests that regardless of how small dx is, the limit at x+dx is still f(x), but acknowledges that the function is undefined when dx equals 0.
  • Some participants discuss the nature of dx, with one stating that dx is defined to be infinitely small, raising questions about the existence of numbers between 3 and 3+dx.
  • There is a contention regarding whether there must be an endpoint before the function becomes undefined, with some arguing that there is always another number between any two real numbers.
  • One participant emphasizes that if the limit from the left and right of a point differ, then there is no limit at that point.
  • Another participant clarifies that "3 + dx" is not a number if dx is considered in the context of derivatives, and that the concept of infinitesimally small numbers can lead to confusion.
Participants express differing views on the nature of dx and its implications for limits. There is no consensus on whether the limit of 3+dx exists, and the discussion remains unresolved regarding the interpretation of infinitesimal quantities and their role in calculus.
Participants reference the definitions of limits and derivatives, indicating that misunderstandings may arise from informal interpretations of mathematical symbols like dx and dy. The discussion touches on foundational concepts in calculus that may not be fully grasped by all participants.
CuriousBanker
Hello.
Let us say that we have a graph f(x)=2x when x does not equal 3, and f(x)=undefined when x=3
The limit of f(x) as x→3, is still 6.
But what about the limit of 3+dx? Does it exist?
I am not up to the derivatives section of my class, so maybe there is something I am not understanding yet.
Because 3+dx is the smallest possible number after 3...and the limit of 3+dx=2(3+dx)=6+dx, if you just plug it into the function. But, immediately to the left of 3+dx, f(x) is not defined, so the graph isn't getting closer and closer to 3+dx as you approach it from the left hand side...because the graph is actually getting closer and closer to being undefined.
So would the limit not exist for 3+dx in this example?
Thanks
if you consider dx to be delta x then the limit at x+deltax = f(x+deltax)
it doesn't matter how small delta x is it could be .1 .01 .001 ... or .000000000000000000000000000000000000000000001 and smaller
and the limit is still by definition of the function f(x) still f(x)
only when x + delta x = 3 ie delta x = 0 is the limt 6 but the function is undefined. It may boggle your mind in a physical sense but when doing math you live in a geometrical world where things can have zero size (a point) zero length or zero thickness (a plane)...
But isn't DX defined to be infinitely small? So that nothing could be in between 3+DX and 3?
No matter what non-zero value you choose for dx there is always a point 3 + dx/2 between 3 + dx and 3.
True. Still, doesn't there have to be SOME number over there where there's no limit ? There has to be some endpoint before the function becomes undefined...no?
There is no limit at x if the function jumps at x. So if you find that the "limit" of f(x) at x approaching from the left is different from approaching from the right, you say there is no limit at x.
What number is it in the function I described where the function jumps?
No! As a previous post said, there is ALWAYS another number between two different real numbers.
Unless you are working with hyperreal numbers (and from your OP I don't think you are), "3 + dx" is not a number, if "dx" is supposed to mean something related to "dy/dx". Vague ideas about "infinitesimally small numbers" will only confuse you. There is no such thing as "the smallest possible number after 3".
If dx is an (ordinary) real number, if doesn't matter if it's 0.0001 or 10-1000000000000000000. There are an infinite number of different numbers between 3 and 3+10-1000000000000000000, just like there are an infinite number between 3 and 3.0001.
But don't feel too bad about having problems with this. The ancient Greeks got tied in knots as well over the paradox of Achilles and the tortoise, etc.
I doesn't jump at any number "in" the function, because you said the function was not defined for the number 3.
I understand. That's crazy
No.
In the standard texts on calculus "DX" by itself has no meaning. (In the somewhat eccentric approach of "nonstandard analysis", it might have.) The use of symbols such as "dy" and "dx" as if they were numbers is a handy way to remember certain rules in calculus. It is a mnemonic device. You can also made intuitive idea of some ideas in calculus if you think of "dy" and "dx" as numbers. However, thinking this way sometimes leads to wrong conclusions. There is no isubstitute for understanding the actual definitions of limit and derivative (the so-called epsilon-delta definitions).
  • · Replies 29 ·
  • · Replies 16 ·
  • · Replies 20 ·
