What is the locus (unsure if this is the right word) defined by these equations?
  • Thread starter Thread starter tamtam402
tamtam402
Using the Ax+By+Cz+D= 0 equation for planes, where D = -(Axo, Byo, Czo)
Find the locus given by the equation if A and B = 0
note: I'm not 100% sure if locus is the right word, english isn't my primary language.
Given above.
Well, if A and B = 0, the equations can be written as Cz+D = 0.
Which means z = -D/C = (0x + 0y Czo)/C = zo
Since we're in a 3 dimensions space, the way I see it both x and y are unrestricted and can take any values. Does that mean the locus defines a plane parallel to the X and Y axis, at a Z value of Zo?
One more thing. The book gives an example, stating that if A=0 then the equation defines a plane parallel to the X axis. Shouldn't it say perpendicular, instead of parallel?
Your answer, that's it's a plane parallel to the X and Y axes, is correct. But why are you writing D = -(Axo, Byo, Czo)? That looks like a vector to me. That doesn't make sense, a form like Ax+By+Cz+D=0. D should be a scalar, i.e. a simple number.
The plane z=1 is parallel to x axis, isn't it? That has A=0.
Yes sorry, I meant D = - (Axo + Byo + Czo),
A,B and C being the components of the normal vector N=(A,B,C)
and xo, yo, zo being the coordinates of a point on the plane Po:(xo,yo,zo).
Yeah I noticed my mistake after posting that. I somehow misunderstood A=0 for x=0. Thanks for the help!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
