What is the Magnitude of Acceleration?
The term "magnitude of acceleration" refers to the absolute value of acceleration, which indicates its strength without direction. For a straightforward example, if acceleration is 4 m/s in a forward direction, the magnitude is simply 4. In cases where acceleration is expressed in vector form, such as 4i + 3j, the Pythagorean theorem is used to calculate the magnitude. This involves finding the square root of the sum of the squares of its components. Understanding these concepts is essential for grasping the fundamentals of physics.
rachael
what does "what is the magnitude of the accelaration" means?
thank you
Do you know what a vector is?
If not, then "magnitude of the acceleration" means the absolute value of the acceleration.
i don't still get it
could you do a simple example for me?
is when you use pythagros theorem to find the magnitude?
If there was an acceleration of 4m/s forwards, then the magnitude would just be the 4. If you have been given it in vector form (e.g. 4i + 3j[/j]) then Pythagorus would have to be used.
thank you...
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
