Chemistry What is the mass of one mole of aluminum?
The mass of one mole of aluminum is 26.981 grams. The discussion includes calculations for the masses of various compounds and the conversion of grams to moles for different substances. For the final question regarding the number of moles in 8.30 x 10^25 molecules of H2O, the correct answer is determined to be 138 moles, using Avogadro's number for conversion. Participants clarify the method of solving the equation, emphasizing the importance of proper placement of values in the formula. The conversation highlights the collaborative effort to verify calculations and understand mole conversions.
AngelShare
I have almost my entire worksheet done but I wanted to check my answers and get some help with the final question.:smile:
What is the mass of one mole of hydrogen?
1.008 g
What is the mass of one mole of carbon dioxide, CO2?
4.4009 x 10^1 g
What is the mass of one mole of sulfuric acid?
9.8079 x 10^1 g
How many moles in 3.00 g H2SO4?
.030 mol
How many moles in 12.0 g CH4?
.748 mol
How many moles in 3.40 x 10^1g CaO?
.606 mol
How many moles in 13.4 g SO2?
.21mol
What is the mass of 0.369 mol N2?
10.337 g
What is the mass of 10.0 mol Ca(NO3)2?
1641 g
What is the mass of 1.94 x 10^-3 mol C6H12O6?
.340 g
What is the mass of 0.0112 KCl ?
.840 g
How many particles in 25.9 mol Fe ?
1.56 x 10^25
How many particles in 0.30 mol NaCl ?
1.8 x 10^23
How many moles in 4.7 x 10^24 atoms Cu?
7.8
This is the one I need help with:
How many moles in 8.30 x 10^25 molecules H2O?
138
245
213
156
I hope I at least did the other ones correctly.:smile:
Hi,
I saw a few of the first ones and they seemed right... sry, kind of lazy to check all of them.
for the last one
1 mole = 6.022*10^23 molecules ... in other words:
___1mole________________ = ___x-moles_____
6.022*10^23molecules_____8.30 x 10^25molecules
now solve for x just by multiplying 8.30*10^25
which gives you 137.8279641 moles.
Now, if you count sig. digits that would be 138 moles.
I don't blame ya, it's a wonder that I did them all myself.:smile:
How are you getting that? I'm a bit confused...I'm assuming, hopefully correctly, that you meant to put the 8.30 x 10^25 on the top, not the bottom? Otherwise, I'm lost.:-p
Its an equation. when you multiply 8.30*10^25 on both sides, the 8.30*10^25 on the right side cancels out and you put it on the left side too ( on top of the equation) then just divide, and as you see, molecules cancel out, leaving you with just moles.
Remember you are solving for the variable "x-moles"
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
11K
