What is the Matrix Notation for a Rotation About the Origin in ℝ2?
  • Thread starter Thread starter phyzz
    Rotation
The discussion revolves around finding the matrix notation for a rotation about the origin in ℝ2, specifically concerning the transformation of the point P = (4,3) to ρ(P) = (3,4). Participants are exploring the angle of rotation and its representation in matrix form.
  • Participants discuss calculating the angle of rotation using arctangent functions and the cosine of the angle derived from vector relationships. There are inquiries about determining sine and cosine values without a calculator, and some suggest using trigonometric identities. Others mention the geometric interpretation of the points involved and the properties of right triangles.
The discussion is active, with participants offering various approaches to the problem, including the use of trigonometric identities and geometric insights. There is no explicit consensus, but several lines of reasoning are being explored, indicating a productive exchange of ideas.
Some participants question the assumptions about the angles involved and the nature of the triangle formed by the points. There is also mention of homework constraints regarding the use of calculators and the need for analytical methods.
phyzz
A rotation ρ about the origin in ℝ2 drives the point P = (4,3) to the point ρ(P) = (3,4).
Find the angle of rotation as well as its matrix notation.
Ok so I made a sketch and I realized I needed to find θ = θ1 - θ2 where θ1 and θ2 equal arctan(4/3) and arctan(3/4) respectively.
I guess it's correct but then how would I work out the sin and cos of that angle θ without a calculator?
SO. I worked out the cosine angle between the vectors 0P and 0ρ(P) and got cosθ = 24/2√25
But now I don't know how to work out the sine!
My goal is to replace everything into the ℝ2 rotation matrix (row 1; row 2):
(cosα -sinα; sinα cosα)
and express as g(x) = Ax + v
Thanks a lot!
A point at ##P=(a,o)## is at the end of the hypotenuse of a right-angled triangle with adjacent side ##a## and opposite side ##o## ... so the hypotenuse has length ##h=\sqrt{a^2+o^2}## and you can find sine cosine and tangent by SOH CAH TOA.
hi phyzz! :smile:
sec2 = 1 + tan2
cos2 = 1/sec2
sin = cos*tan :wink:
How do you know that this is a right angle though?
tiny-tim said:
hi phyzz! :smile:sec2 = 1 + tan2
cos2 = 1/sec2
Ohhhhh my bad I didn't see it at first. I just used sin^2 + cos^2 = 1
and the cos of the angle I found between the two vectors.
Thanks!
... in fact, P=(3,4) and Q=(4,3) each make a special kind of triangle.
The rotation angle is the difference between complimentary angles in this triangle - if you recall your special triangles, you don't need the trig.
Of course, since you know the start and finish, you could just expand the matrix equation into a pair of simultanious equations and solve them?
Thank you Simon Bridge!
In other news, when I work out (in this case a is a constant) [tex]\left \| T_{\gamma}(t) \right \| = \left \| \frac{1}{\sqrt{1 + a^{2}}} (-asin(t),\sqrt{1+a^{2}}cos(t),-sin(t)) \right \|[/tex]
I know I can just do [tex]\left \|(-asin(t),\sqrt{1+a^{2}}cos(t),-sin(t)) \right \|[/tex] and then multiply by the constant [tex]\frac{1}{\sqrt{1 + a^{2}}}[/tex]at the very end.
My question:
Given that [tex]N_{\gamma}(t) = \frac{1}{\sqrt{1 + a^{2}}} (-acos(t),-\sqrt{1+a^{2}}sin(t),-cos(t))[/tex]
and I want to work out [tex]T_{\gamma}(t) \times N_{\gamma}(t)[/tex]
can I just do [tex]\frac{1}{\sqrt{1 + a^{2}}} \frac{1}{\sqrt{1 + a^{2}}}[/tex] multiplied by the result of [tex](-asin(t),\sqrt{1+a^{2}}cos(t),-sin(t))\times (-acos(t),-\sqrt{1+a^{2}}sin(t),-cos(t))[/tex]? Thanks so much again!
Don't see the connection of all that with your question... in ##T_\gamma(t)\times N_\gamma(t)## - is that ##\times## supposed to be a cross product?
FYI: putting a backslash in front of the function name turns ##sin\theta## into ##\sin\theta##
Yes, cross product
Thanks for the tip!
If ##\vec{u}=a(x,y,z)## and ##\vec{v}=b(p,q,r)## then is ##\vec{u}\times\vec{v}=ab## ... is that your question?
Does a cross product usually produce a scalar?
What I meant was if we have constants in front of two vectors we want to cross product, are we allowed to multiply the constants together and perform the cross product to the vector bits?
Sorry for the vagueness!
Yes, the "associative" law holds for the cross product: [itex](a\vec{u}\times (b\vec{v})= (ab)(\vec{u}\times\vec{v})[/tex][/itex]
