What Is the Maximum Power on an Impedance Z?
The discussion focuses on calculating the maximum power delivered to an impedance Z using Thevenin's theorem. The user initially miscalculated the power, suspecting errors in the impedance or voltage values. After confirming the Thevenin values, they explored the maximum power theorem for complex impedance, realizing that the imaginary part of the load impedance should cancel out the source impedance's imaginary component. This led to the correct power calculation of P=64, confirming that only the real part is relevant for maximum power. The conversation emphasizes the importance of accurately matching impedance for optimal power transfer.
crom1
Find the maximum power on a impedance Z.
I got as Thevenin impedance Zt=4+j4 and Ut= 32 V, but since my solution for power is wrong, something is wrong with either impedance or voltage (or both).
If point A is above Z, and point B is under Z, looking from A to B I get for impedance:
First j4 , then since I have current source in of the branches, I ignore impedances in that branch and get j4+(j4-j4+4) and since there is voltage source I ignore 2-j12.
For Thevenin voltage, I tried with superposition, and if potential of B=0, I get that for A:
$$ \varphi_A= 16 \angle 0 + 4 \angle 0 \cdot 4 + 4 \angle 0 \cdot j4 + 4 \angle 0 \cdot (-j4)=32 $$
Your Thevenin values look okay. How did you calculate the maximum power?
Likes crom1
I=Ut/(Z+Zt)=2-j2 , P=I^2 Z = 32-32i = 32 sqrt(2) , And the solution says 64.
What value did you give to the load impedance Z?
Likes crom1
Z=Zt=4+j4
crom1 said:
Z=Zt=4+j4
Check the maximum power theorem for complex impedance. I think you'll find that the imaginary part of the load should nullify the source impedance's imaginary component.
Likes crom1
You're right. I now get P=64-j64, do I now just take real part to get P=64?
Yup.
Likes crom1
