What is the maximum speed of a proton if its kinetic energy is 1.28x10^-14 J?
The discussion revolves around determining the maximum speed of a proton given its kinetic energy of 1.28x10^-14 J. The subject area includes concepts from kinetic energy, electric potential energy, and particle physics.
  • The original poster attempts to apply the kinetic energy formula but struggles with the lack of velocity. They also explore the relationship between electric potential and kinetic energy but express confusion about how to proceed without knowing the velocity.
  • Some participants question the implications of charge and electric potential on the potential energy of the proton during acceleration.
  • Others suggest using the relationship between potential energy and charge to find a way to calculate the maximum speed.
Participants are actively exploring different approaches to relate kinetic energy and electric potential energy. Some guidance has been offered regarding the use of potential energy equations, but multiple interpretations and methods are still being discussed.
There is mention of the joule as the SI unit of energy and the common use of electron-volts in particle physics, indicating a potential conversion consideration. The original poster's confusion about the velocity and energy relationship remains a point of discussion.
lilymay992
Hi! So for my a levels I’ve been doing practice papers and I’m stuck. I have to calculate the kinetic energy of a proton after acceleration except I’m only given the charge of +1.6x10^-19 , a potential difference of 80kV, and a mass of 1.7x10^-27kg
Kinetic energy = 1/2 x mass x velocity^2
So first I tried to use KE=1/2 x m x v^2 but then realized I didn’t have the velocity and I can’t figure out a way to obtain it. I then tried to work out the energy using a different equation, W= q x v but that left me with 1.28x10^-14 J which seemed too small.
I also then have to calculate the maximum speed of the proton which I’m confused at how to do if I don’t have the velocity.
Thanks in advance!
You have the charge and you have the change in electric potential. What does this mean for the change in the potential energy of the proton and where does this potential energy go during acceleration?
Oh so do I use V= p.e. / q because the electrical energy has been transferred to kinetic energy during the acceleration?
That does seem like a viable option, yes.
Thank you for your help!
Note that the joule is the SI unit of energy. In particle physics, however, it's more usual to use the electron-volt as the unit of energy. This is the energy gained by an electron ( or other particle with the same charge) accelerated through 1 volt.
Another way to do your problem is to use the immediate answer in terms of electron volts and then look up the conversion to joules.
  • · Replies 54 ·
12K
  • · Replies 21 ·
  • · Replies 20 ·
