What is the minimum force at this angle that will move the box?
12 replies · 5K views · last reply
zehkari
[/B]
Diagram of a box on a horizontal floor pushed by force F directed down and to the left at angle θ below the horizontal, with the angle marked against a dashed horizontal line; the printed problem asks for F = μs W sec θ / (1 − μs tan θ).
2. Homework Equations
Fs = Nμ
W = mg
Fy = Fsin(θ)
Fx = Fcos(θ)
[/B]
Hello all at PhysicsForums,
I have a question on angled force and static friction. From my attempt below, I think I have found the maximum force required and would need to get the minimum. Then using trigonometry I could derive sec(θ) and tan(θ).
Have tried some algebra to get to the quation in the question, but I have been unsuccessful.
If anyone could help me that would be great,
Thanks.
Zehkari.
Handwritten free-body diagram of a box on a horizontal surface with a force F at angle θ pushing down-left, labelled Fx = F cos θ and Fy = F sin θ, with N and Mg shown, followed by a handwritten derivation of F = μs Mg / (cos θ + μs sin θ).
  • Handwritten free-body diagram of a box on a horizontal surface with a force F at angle θ pushing down-left, labelled Fx = F cos θ and Fy = F sin θ, with N and Mg shown, followed by a handwritten derivation of F = μs Mg / (cos θ + μs sin θ).
  • Diagram of a box on a horizontal floor pushed by force F directed down and to the left at angle θ below the horizontal, with the angle marked against a dashed horizontal line; the printed problem asks for F = μs W sec θ / (1 − μs tan θ).
Something with using the identity
cos2(θ)+sin2(θ) = 1
so
1 - sin2(θ) = cos2(θ)
cos2(θ)+sin2(θ) = 1
so
Nope. even simpler.
Chandra Prayaga said:
Try that!
Dividing the euqation by cos(θ), I get:
F/cos(θ) = mg.μ/1+μ.tan(θ)
so,
F = mg.μ.cos(θ)/1+μ.tan(θ)
I just noticed that you have a sign error in the denominator of your solution attempt. The μssin(θ) term should have ended up negative. You'll have to go through your work again to find out where the sign error occurred.
No, check your algebra. I'd suggest manipulating only the right-hand side, leaving the left alone. Divide the numerator and denominator by cos(θ) (hence effectively multiplying the right-hand side by 1).
so,
Please check your work, before this last step. For example, check the line you wrote for F cosθ = (mg - F sinθ) μs
Thank you gneill and Chandra Prayaga, makes sense now. Apologies for the silly error on the sign.
I hope that you've reached the desired result? Otherwise, please post your work and we'll be happy to offer more help.
The error is in the diagram that shows N=mg - μkF sinθ. Because the external force is pushing down and across, the reaction force should be greater than mg, not less.
I think its good now. As the numerator is divided by cos(θ), you get sec(θ). Then as the denominator is divided by cos(θ), you get 1-μ.tan(θ). Thank you for your help.
Thank you, yes I have it as greater than now.
