What is the Minimum Force Required for the Bracket?
13 replies · 6K views · last reply
Emilio
If the resultant force acting on the bracket is required to be a minimum, determine the magnitude of F1. Set Φ=31°
Free-body diagram of a bracket on a wall with forces F1 at angle phi from the y-axis, F2 = 200 N along the x-axis, and F3 = 260 N with a 5-12-13 slope triangle; a 30 degree angle is marked between F1's line u and the x-axis.
Fx=F(cos(θ))
Fy=F(sin(θ))
First I tried to find ∑Fx and ∑Fy
ΣFx=0=200+cos(67.38)260+cos(59)F1x
ΣFy=0=sin(67.38)260+sin(59)F1y
Solving for F1, I got
x=-384.06
y=279.99
And then to find the magnitude, I found the root of the sum of their squares
√(-384.06² + 279.99²)=479.335N
which was wrong.
A few things: I know the x-component can't be negative, it makes no sense, but I don't know what to change to make it positive. I also don't know what is implied by "required to be a minimum."
Emilio said:
Set ϕ = 31
Something important missing here?
I'm not sure what you mean, am I missing a step or did I leave something out? All it says in the prompt is "Set ϕ = 31° ."
There's a degree symbol? Typesetting sometimes misses symbols. Do you think it says set F1's angle to be 31°?
NascentOxygen said:
There's a degree symbol? So what did you set to be 31°?
Oh sorry, I see a degree symbol in my original post, not sure why it doesn't show up.
I did set ϕ = to 31°, but I used 59° in my equations just because it was a little easier to visualize for me. I didn't think it would make a difference because sin(31)=cos(59).
The phi isn't showing up on my screen, it's just a blank space.
Oh that's odd, I even see the phi in your quoted text. I rewrote it using the editor instead of copy-pasting symbols, so hopefully it looks a little more accurate.
Your mistake is in equating the sum of the components to zero. That would certainly be ideal, but with the angle fixed all you can aim for is a minimum, not zero.
What does it mean to find a minimum? A minimum force that would keep it in equilibrium? The smallest possible resultant force?
The resultant sum of those 3 external forces is to be its smallest possible value.
So instead of ∑Fx,y being equal to 0, they should equal the smallest possible value?
Wouldn't that be Fx=0 and Fy=0?
The character set you are using seems problematical. I saw Fy= -∞ in your post, which seemed a puzzling value; yet when I quote that to respond, that -∞ has transformed into a 0. You should be using the characters that appear when you tap ##\Sigma## in the forum editor toolbar, or else use Latex.
You can't make the resultant horizontal force equal to zero, as all forces have a component to the right---there is not going to be any cancelling in the x-direction.
I had typed -∞ at first, but after considering it, I realized it didn't make sense so I changed it to 0.
So I can't set Fx=0, but I want to get this value as small as possible. Do I set up a limit as Fx approaches 0?
Just my caching problem, then.
Probably not.
You had the right idea back in your opening post:
So go back to your first post, and improve on that. If force up is +, then downwards will be -
That won't be F1x, it's just F1 because the cos converts it to the horizontal component.
