- #36
Nachtwolf
- 7
Hahahaha!The only 4 hits that are returned by OVID for the PsycINFO database when queried for the keyphrase Equatorial Guinea are chimpanzee and lowland-gorilla studies.
--Mark
Translation: we don't have any data on secular trends in Equatorial Guinea, or any nation which is undergoing a demographic or economic transition. However, if we apply the Flynn effect (which has been documented in some economically advanced countries), we'll be able to adjust the "National IQ" of Equatorial Guinea downwards, and that strengthens our case, so we'll do it.hitssquad, quoting Lynn and Vanhanen:A factor that needs to be taken into account in making these calculations is that the mean IQs in economically developed nations have been increasing since the 1930s. An adjustment needs to be made for this increase when calculating the mean IQs obtained in countries from tests that were adminstered some years before or some years later than the British test with which it is being compared... Mean IQs on the Wechsler tests increased by approximately 3 IQ points per decade from the mid-1930s to the 1990s (Flynn, 1984, 1998) *SNIP
Translation: we have clear evidence that the data from the 1984 study is incompatible with measures we use in the UK. Rather than investigate the cause of this incompatibility, we've chosen to scale the data in a fashion which supports our case (and hope that no one notices our unscientific sleight of hand).ditto A problem in estimating some national IQs is that the samples have scored below the first percentile in relation to British norms. The first percentile is equivalent to an IQ of 65. Where national samples have scored below the first percentile, They have been assigned an IQ of 64.
Flynn effect adjustments were not peformed on national IQs. Flynn effect adjustments were performed on the means of the results of individual IQ studies from which national IQ were subsequently calculated. Some were adjusted downward, and some were adjusted upward. Since some nations' national IQs were calculated from the results of more than one study, and since each study was performed chronologically neither necessarily equidistant, nor necessarily equi-directional, from the year of the relevant test's closest British norming, performing a Flynn effect adjustment merely on national IQs wouldn't be possible in at least some cases.Originally posted by Nereid
Translation: ... if we apply the Flynn effect (which has been documented in some economically advanced countries), we'll be able to adjust the "National IQ"hitssquad, quoting Lynn and Vanhanen:
Merely knowing that Flynn effect adjustments were performed on the results of the studies used to calculate the national IQs, it wouldn't be possible to positively state whether such adjustments weakened or strengthened Lynn's and Vanhanen's case. More information would be needed. If Lynn's and Vanhanen's methods were reproduced without the Flynn effect adjustments, then it could be determined which of either the non-Flynn-adjusted or the Flynn-adjusted version produced the strongest case....and that strengthens our case
Similarly to to the above case, it can't be said merely from knowing the facts presented here whether this adjustment weakened or strengthened Lynn's and Vanhanen's case. A reasonable guess would be that it weakened it, since the result of the adjustment was in each case likely a compression of the score range, and hence likely an overestimation of the national IQs of the nations in question.Originally posted by Nereid
Translation: ... we've chosen to scale the data in a fashion which supports our casehitssquad, quoting Lynn and Vanhanen:
For question 7, tests and test protocols, the test used was the WISC-R, which stands for the Wechsler Intelligence Scale for Children - Revised. The WISC-R was published in 1974. Presumably, the British norms were collected in years preceding that date.Would you please list the studies of IQ in Equatorial Guinea?
1) the mean (or median, please specify which) from each source
2) the standard deviations about the mean/median
3) tests used to show Gaussianity of the distributions
4) the sample sizes
5) age/gender/population group distribution of each sample
6) sample selection methods
7) tests and test protocols
8) year when the research was done
9) the method(s) used to account for secular effects
10) the size of each such correction[/color]
So far, you have given us (partial) answers to:
1) (partial; you didn't state what measure was reported)
4) {and just how meaningful is a sample of 48, in a population of >400,000?}
5) (partial; "10- to 14- year olds")
7)
8) (partial; "around 1984")
9)
10)
I'm not sure that I said they were; but that makes the shortcomings worse.hitssquad: Flynn effect adjustments were not peformed on national IQs.
Which in the case of Equatorial Guinea was a test on a single sample of 48, done 'around 1984'.hitssquad: Flynn effect adjustments were performed on the means of the results of individual IQ studies from which national IQ were subsequently calculated.
Nereid said:(in message 153227)Would you please list themhitssquad said:ten sources used for the book's assumption of IQ 105 for Japan
This is a very interesting point that seems to cast serious doubt on most of their data. As can be seen here, most of it are from tests on children:selfAdjoint said:I notice that all these standardizations and comparisons were made with tests for children. Since g for adults behaves differently from g in children, it seems regrettable that no adult tests were included. Also it seems a stretch to assume a causal relationship from childhood IQ to adult-oriented economic performance, without some data to split out the latent variables.
What is an inherent IQ?Nereid said:Lynn is on record as saying that men and women have different inherent IQs
http://www.gnxp.com/MT2/archives/001502.htmlNereid said:what data is there to show that the Flynn effect (secular variation in mean IQ, using the same test) is the same in all countries (specifically, the US and Japan)?
