What is the output voltage in this circuit?
  • Topic: Engineering
  • Thread starter Thread starter dexterdev
    Circuit Output Voltage
5 replies · 3K views · last reply
dexterdev
Circuit schematic: source V with U=1V connected to node A, with R1 R=50 Ohm in series with V1 U=1 V to ground.
I would like to know the output voltage in this circuit at label A. (I am a beginner , sorry for stupid questions if any? )
The circuit setup is a sine wave source (ideal) in parallel with DC source series with a resistor.
-Devanand T
point A is at other end of AC source V
so voltage at A is V itself ...
It is all dependent on the source impedance of the voltage source V. The way it is drawn, Rsource (Zsource) =0, so point A will be at V volts (it will follow the sinusoid) since it is a direct short.
if there were an R in between the source and node A, then you could determine the voltage there by using superposition and treating each voltage source separately (making the other voltage source 0) and using the voltage divider rule. The resulting value of A is the sum of the contributions from each source.
dexterdev said:
what about dc source plus resistor
it doesn't matter .
