What is the Length of the Pendulum?
  • Thread starter Thread starter BoostAdiction
    Length
The discussion centers on calculating the length of a pendulum, its maximum potential energy, and the maximum tension in the cord for a simple pendulum with a 50.0 g bob. The angle of displacement is defined by the equation (theta)=(0.01000rad)cos[(5rad/s)t]. The maximum potential energy (PE) is determined to be equal to the maximum kinetic energy (KE) of 0.196 J, as PE and KE are inversely related in a pendulum's motion. The radial acceleration formula, a = ω²r, is essential for calculating tension in the cord.
  • Understanding of simple harmonic motion
  • Familiarity with the equations for potential energy (PE) and kinetic energy (KE)
  • Knowledge of circular motion dynamics, specifically radial acceleration
  • Basic trigonometry for analyzing angles in pendulum motion
  • Study the derivation and application of the formula for radial acceleration in circular motion
  • Explore the relationship between potential energy and kinetic energy in oscillatory systems
  • Learn how to calculate the length of a pendulum using angular displacement
  • Investigate the effects of mass and angle on the tension in a pendulum's cord
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators seeking to clarify concepts related to pendulum dynamics.
BoostAdiction
Suppose that a simple pendulum consists of a 50.0 g bob at the end of a cord of negligible mass. The angle (theta) between the cord and the vertical is given by: (theta)=(0.01000rad)cos[(5rad/s)t ], where t is time. A. What is the pendulum's length? B. What is the pendulums maximum potential energy? C. What is the maximum tension in the cord?
PE=mgh
KE=1/2mv^2
I got part a. Part b is throwin me off. I know how to find the maximum kinetic energy (KE=5rad/s x .392m x .1 rad) I am confused as to how to find potential, and even more lost on the tension
I have feel like mgh should equal KE because KE is energy in motion and the max potential of a pendulum would mean that its not moving right? As its about to swing the other way?
Hi BoostAdiction! :smile:
Yes, that 's right … or, to put it in more mathematical language, PE + KE = constant, so PE is maximum when KE is minimum … in this case, when KE = 0! :smile:
Hint: tension = radial component of weight minus acceleration … and the acceleration is … ? :smile:
Woot! So in this case...PE=KE and KE = 5rad/s x .392m x .1 rad which equals, .196 J meaning PE does as well..Hopefully. I am going to assume the acceleration is... 0.5 rad/s^2?
BoostAdiction said:
Im going to assume the acceleration is... 0.5 rad/s^2?
Can't work out how you got that … you should be using the formula for radial acceleration in circular motion … and it should depend on the angle. :smile:
Just made a guess on it :D. I can't find the radial acceleration in circular motion...all i found was the derivative of omega/derivative of t
Have you been taught acceleration = v²/r = ω²r? :smile:
  • · Replies 31 ·
