What is the physical size of an electron?
  • Context: High School
  • Thread starter Thread starter rorix_bw
    Electron Physical
The discussion revolves around the physical size of an electron, exploring its characteristics as both a particle and a wave. Participants examine theoretical implications, experimental evidence, and various models related to the electron's size, including its behavior in different environments.
  • Some participants assert that the size of an electron is zero, describing it as a pointlike particle based on quantum field theory and experimental evidence.
  • Others propose that the size of an electron can vary depending on environmental conditions, such as being bound to an atom or existing in a quantum well.
  • A claim is made that while the electron behaves as a wave, its wavefunction can take the size of its container, but the electron itself remains pointlike.
  • Some participants challenge the idea of a zero size, suggesting that research into the electron's shape, such as its electric dipole moment, implies it could have a non-zero size.
  • There is discussion about the classical electron radius, which is a theoretical construct that attempts to describe the electron as a charged sphere, though this model is considered inconsistent with modern quantum mechanics.
  • One participant references Neil Degrasse Tyson's statement about the electron's size being indistinguishable from zero, prompting further exploration of what this means in a scientific context.
  • Concerns are raised about the interpretation of scientific articles and media representations regarding the electron's size and shape, with calls for clarity on the distinction between characterizations and the actual properties of the electron.
Participants express differing views on the size of the electron, with some firmly stating it is zero and others suggesting it may not be. The discussion remains unresolved, with multiple competing perspectives presented.
Participants note that the discussion involves complex interpretations of experimental results and theoretical models, highlighting the limitations of current understanding and the potential for ongoing research to influence these views.
  • #31
Deep, man. Really, really deep.
Thanx.
  • #32
humanino said:
All electrons are but excitation of the same field.
Does this imply an electron 'ether'?
  • #33
humanino said:
you can never know whether they are really one and the same, which came back from the future in the form of a positron.
Can I just make sure I understand the implication of this proposition? Is this implying that, taking the whole 'time-line' into account, that every electron has a positron that it is going to annihilate with it in the future, and vice-versa? Each electron has the 'name' of another positron already on it, so to speak, which is essentially moving the opposite way down the timeline to an inevitable annihilation with that given electron?
And, by implication, in the course of the universe there will have been as many electrons as positrons?
  • #34
As we are in the realm of quantum physics, talking about trajectories of electrons (positions changing with time) must be taken with a large grain of salt.
According to QED, we have an electron/positron field and an electromagnetic field (and, in the extension of QED as used by chemists, one field for every kind of nucleus). These are the real things. (They do not deserve being called ether; the ether of old times has no energy density.)
Trajectories make sense only if one looks at the fields from a coarse-grained point of view and studies an approximate dynamics for distinguishable local aggregations of field strength that may be called particles.
And they are not more accurate than the extensions of these local aggregations - their physical size.
  • #35
humanino said:
which is exactly what was done earlier in this thread with the explicit full vertex operator including the third form factor for the putative electric dipole moment.
Yes, The Gordon decomposition is used in the vertex calculations (In the specific form of
the interaction current of two plane waves with different momenta). Itzykson and Zuber
is a good source. Their treatment is more extensive as most of the others.
Hans.
  • #36
The electron is a point particle. To say it is zero would be misleading. The instruments we use are not sensitive enough to measure the true size or location of an electron. Trying to measure the size of a single electron with our current technology is like trying to pick-up a virus with a pair of tweezers.
  • #37
Back a page someone asked about quantum gravity theories and minimum size. I would agree QM Gravity Theories with there minimum area and minimum volume mean electrons, and everything else, have at least that much area and volume. Likewise string theories with minimum string length set a minimum size for an electron and everything else.
But it is just the naked electron that has this absurdly small size the effective size of the dressed electron is much bigger.
  • #38
I missed to answer
I thought I made it clear that this scenario is only a consistent one rather than a necessity. As a physical scenario, it makes the pretty outlandish and untestable hypothesis that there is a reverse image of antimatter beyond our observable horizon.
But please note that there are other pretty outlandish ideas, which are still sometimes mentioned in textbooks and university lectures on introductory quantum field theory. For instance, Dirac's sea of negative energy electrons, which is essentially the historical prediction for antiparticles (although at first, Dirac hoped he could explain protons with it). The Dirac see also implies that all electrons are the same, except with a many particle view instead of a field. Its pedagogical value is now obsolete, because for one thing it cannot explain antiparticles for bosons.
  • #39
Trajectories of electrons, this brings a question from me that might relate well with this thread.
If in ones mind a virtual image can be formed, an electron slowed in speed and a path inline and along side of a returning space shuttle craft, if the electron and it's magnetic field could be seen, would it not look almost the same as the vapor trail of the spacecraft ?
If this is near correct, the reduction of size to almost zero should be easy for most to see in their minds eye.
  • · Replies 40 ·
  • · Replies 25 ·
  • · Replies 22 ·
  • · Replies 18 ·
  • · Replies 100 ·
12K
