What is the point P(1,4) transformed to by the matrix A?
  • Thread starter Thread starter TsAmE
    Linear
The discussion focuses on finding the 2x2 matrix A that represents a projection onto the x-axis followed by a clockwise rotation of π/4 radians. The correct transformation matrix is derived from the rotation matrix \begin{pmatrix} \cos\frac{\pi}{4} & \sin\frac{\pi}{4} \\ -\sin\frac{\pi}{4} & \cos\frac{\pi}{4} \end{pmatrix} and the projection matrix \begin{pmatrix} 1 & 0 \\ 0 & 0 \end{pmatrix}. The resulting matrix A is \begin{pmatrix} \frac{1}{\sqrt{2}} & 0 \\ -\frac{1}{\sqrt{2}} & 0 \end{pmatrix}. The final transformation of the point P(1,4) yields the coordinates (\frac{1}{\sqrt{2}}, -\frac{1}{\sqrt{2}}).
  • Understanding of 2x2 matrices and matrix multiplication
  • Knowledge of rotation matrices in two-dimensional space
  • Familiarity with projection matrices
  • Basic trigonometry, specifically sine and cosine functions
  • Study the derivation of rotation matrices in 2D geometry
  • Learn about the properties and applications of projection matrices
  • Explore the concept of transformations in linear algebra
  • Practice matrix multiplication with various transformation matrices
Students studying linear algebra, mathematicians interested in transformations, and anyone working with computer graphics or physics simulations involving 2D transformations.
TsAmE
Find the 2 x 2 matrix A which represents a projection onto the x-axis, followed by a clockwise rotation through pi/4.
None
\begin{pmatrix} cos\frac{\pi}{4}&sin\frac{\pi}{4} \\ -sin\frac{\pi}{4}&cos\frac{\pi}{4}\end{pmatrix} \begin{pmatrix} 1&0 \\ 0&0\end{pmatrix}
\begin{pmatrix} \frac{1}{\sqrt{2}}&\frac{1}{\sqrt{2}} \\ -\frac{1}{\sqrt{2}}&\frac{1}{\sqrt{2}}\end{pmatrix} \begin{pmatrix} 1&0 \\ 0&0\end{pmatrix}
\begin{pmatrix}\frac{1}{\sqrt{2}} & 0 & 0 \\ -\frac{1}{\sqrt{2}} & 0 & 0\end{pmatrix}
but the correct step was \begin{pmatrix}\frac{1}{\sqrt{2}} & 0 & \\ -\frac{1}{\sqrt{2}} & 0 & \end{pmatrix}
I don't understand why the 2nd column of the 2nd matrix hasnt been multiplied with the first matrix's row.
None
Why do you have three columns in the matrix above? The product of two 2 x 2 matrices is a 2 x 2 matrix.
I am puzzled why you have the product of 2x2 matrices yielding a 2x3 matrix? Perhaps this is the source of your problem?
If not, then notice that the (dot) product of the 2nd column of the 2nd matrix and the 1st row of the 1st matrix will be the (1,2)-entry in the product of the two matrices. Which in your case is 0, as shown in the book.
So I am not really sure what you are asking.
Nevermind, I found what I did wrong :smile:. For the second part of the question it asked: To which point does the matrix A take the point P(1,4)?
Attempt:
\begin{pmatrix}\frac{1}{\sqrt{2}} & 0 & \\ -\frac{1}{\sqrt{2}} & 0 & \end{pmatrix} \begin{pmatrix}1 & 0 & \\ 0 &4&\end{pmatrix}
=\frac{1}{\sqrt{2}}\begin{pmatrix}1 & 0 & \\ -1 & 0 & \end{pmatrix} which is the same as:
<br /> \begin{pmatrix}\frac{1}{\sqrt{2}} &amp; 0 &amp; \\ -\frac{1}{\sqrt{2}} &amp; 0 &amp; \end{pmatrix}<br />
but I don't get why the answer is (\frac{1}{\sqrt{2}}, -\frac{1}{\sqrt{2}})
Attempt:
\begin{pmatrix}\frac{1}{\sqrt{2}} &amp; 0 &amp; \\ -\frac{1}{\sqrt{2}} &amp; 0 &amp; \end{pmatrix} \begin{pmatrix}1 &amp; 0 &amp; \\ 0 &amp;4&amp;\end{pmatrix}
This is wrong. The matrix on the left above is your transformation matrix that projects a vector onto the x-axis and then rotates the projected vector 45 degrees clockwise. You should NOT be multiplying a matrix with that matrix. Instead, multiply the vector(1, 4). (This vector extends from (0, 0) to the point (1, 4).
As a sanity check, what do you get when you project <1, 4> onto the x-axis? What vector do you get when you rotate the projected vector by 45 degrees clockwise?
You should be drawing sketches of these vectors if you aren't doing so already.
TsAmE said:
=\frac{1}{\sqrt{2}}\begin{pmatrix}1 &amp; 0 &amp; \\ -1 &amp; 0 &amp; \end{pmatrix} which is the same as:
