It has been stated previously: a voltage source will not change the capacitance between nodes, and it is not required to determine the capacitance between nodes. That problem does not ask you to find a potential difference between nodes, just capacitance.gracy said:I had already posted.
As in here
https://www.physicsforums.com/threads/equivalent-capacitance-circular-arrangement.845579/
I was asked to find equivalent capacitance in between A and B but there is no voltage source between those two points.
I think I am missing something.
What is the Potential Difference Between c and d in This Circuit?
- Thread starter gracy
- Start date
- Tags
- Capacitance Equivalent
108 replies · 12K views
- 1,583
gracy said:But I have seen some problems in which I was asked to determine equivalent potential between two points and there was no voltage source.
Equivalent capacitance is not equivalent potential.gracy said:I had already posted.
As in here
gracy
- 2,486
- 83
I wrote that mistakenly.But my question is valid.SammyS said:Equivalent capacitance is not equivalent potential.
- 11,986
- 1,583
I don't think your question is valid.gracy said:I wrote that mistakenly.But my question is valid.
You said: "But I have seen some problems in which I was asked to determine equivalent capacitance between two points and there was no voltage source."
Then you posted a link to a thread in which you were asked to find equivalent capacitance and in which there was no voltage source..
gracy
- 2,486
- 83
Yes,what is wrong in here?SammyS said:But I have seen some problems in which I was asked to determine equivalent capacitance between two points and there was no voltage source."
gracy
- 2,486
- 83
Basically I was saying I don't think we need a voltage source in order to determine the equivalent capacitance as ch1995 said not @gneill .Quotation is wrong.
As I have seen some problems in which I was asked to determine equivalent capacitance between two points and there was no voltage source.@gneill asked me to post those problems that's what I did.
- 11,986
- 1,583
Oh you edited that thread, Thread # 26. which originally said,gracy said:Yes,what is wrong in here?
"But I have seen some problems in which I was asked to determine equivalent potential between two points and there was no voltage source."
gracy
- 2,486
- 83
Yes,I wrote potential instead of capacitance .See my post 33.
- 11,986
- 1,583
It would certainly help to have pointed out what the mistake was that was being referred to, and in post #26, when you edit the post, it helps to point out what change you make if the change is significant.gracy said:I wrote that mistakenly.But my question is valid.
- 3,638
- 1,014
Related to what I have advised before you need to be less plodding.
If I tell you the answer to this question (the one you started with) is obvious and not even needing to write down any calculations, does that make it obvious?
Relevant equations.
1. The potential drop (voltage as you and I naturally say, but I correct myself - pedantically) across a capacitor depends on some way or other that doesn't matter now on just the charge and capacitance, nothing else.
2. About the charges on capacitors in series we know something. Well we have gone into it recently so hopefully we do.
3. The capacitances are given in the problem. Is one, by any chance, related to another?
Relevant equations.
- 1,173
gracy said:Then what voltage source does?
Suppose V=100V. In this problem, if you were asked to calculate the total amount of charge supplied by the source, you'll first calculate the equivalent capacitance between a and b (what you calculated earlier as 8μF ) and then use Q=C(eq)*V.. This is where adding a voltage source and calculating the equivalent capacitance matter. Because again, equivalent capacitance is always the one which is "seen" by a source connected between those points.
gracy
- 2,486
- 83
I want to know is voltage divider rule applicable only when two resistance are there in series,I never found R3 in the below formula.I know that it is applicable for capacitors also what I am asking is it applicable only when two components are in series I know also that it is applicable in series connection only ,I am trying to stress on twogneill said:voltage divider
- 1,014
I can probably guess what you're after with this question but shouldn't have to.
If you are asking whether there is any analogy between logic and equations of capacitors in series and resistors in series, yes there is a kind of analogy.
With resistors in series what is the physical quantity that is the same in each of them?
With capacitors in series what physical quantity is the same in each of them? - you have recently discussed this in detail.
If several equal resistors are in series how is the potential difference over each one related?
May be suggestive for your problem.
- 1,173
Do you know how the formula for voltage divider is derived? Do you know Ohm's law?gracy said:I want to know is voltage divider rule applicable only when two resistance are there in series,I never found R3 in the below formula.I know that it is applicable for capacitors also what I am asking is it applicable only when two components are in series I know also that it is applicable in series connection only ,I am trying to stress on two
gracy
- 2,486
- 83
##V##=##I##Rcnh1995 said:Do you know Ohm's law?
- 1,173
Right. Now can you apply it to derive the voltage divider formula?gracy said:##V##=##I##R
gracy
- 2,486
- 83
cnh1995 said:derive the voltage divider formula?
Vs = I × Rtot
However, we know that Rtot = R1 + R2 so we substitute this into the equation above to give the following expression.
Vs = I × (R1 + R2)
The above expression transposes to give the following expression for current.
I = Vs / (R1 + R2)
We know that the following expression for the output voltage is true.
Vo = I × R2
Substituting the previous expression for current into the above equation, we get the following.
Vo = Vs × R2 / (R1 + R2)
gracy
- 2,486
- 83
I think we can use it for any number of resistance.
- 1,173
gracy said:Vs = I × Rtot
Vs = I × (R1 + R2)
I = Vs / (R1 + R2)
Vo = I × R2
Vo = Vs × R2 / (R1 + R2)[/QUOT
Exactly..gracy said:I think we can use it for any number of resistance.
gracy
- 2,486
- 83
But it is derivation for resistance as we know ohm's law can't be applied for capacitors,how to derive this for capacitors?
- 1,173
Use Q=CV. In series circuit, Q is same on each capacitor. Can you proceed from here?gracy said:But it is derivation for resistance as we know ohm's law can't be applied for capacitors,how to derive this for capacitors?
- 1,173
It will be not as straightforward as it is for resistors. Because resistors is series add directly while capacitors in series don't.. You can derive it but can't memorize it because it will change with number of capacitors.gracy said:But it is derivation for resistance as we know ohm's law can't be applied for capacitors,how to derive this for capacitors?
gracy
- 2,486
- 83
What is Vo?gracy said:Vo
- 1,173
gracy said:What is Vo?
Voltage across R2..gracy said:Vo = I × R2
gracy
- 2,486
- 83
In general?
- 1,173
In general it is the output voltage..gracy said:In general?
gracy
- 2,486
- 83
Voltage across last resistance/capacitor?cnh1995 said:it is the output voltage..
gracy
- 2,486
- 83
Emf of battery?gracy said:Vs
- 1,173
Not last. It can be across any component. That depends on the problem. Here in this capacitance problem, Vo is voltage between c and d.gracy said:Voltage across last resistance/capacitor?
- 1,173
Right.gracy said:Emf of battery?
Potential difference between 2 points in a capacitor circuit
- vcsharp2003
- · Replies 30 ·
- Introductory Physics Homework Help
- Replies
- 30
Potential difference between two points in an electric field
- NoahCygnus
- · Replies 1 ·
- Replies
- 1
Are lost volts the difference between EMF and terminal potential difference?
- homeworkhelpls
- · Replies 4 ·
- Replies
- 4
Finding the potential difference between 2 points in a circuit
- ellieee
- · Replies 6 ·
- Replies
- 6
Potential difference between points d and c in circuit
- Omar FTM
- · Replies 7 ·
- Replies
- 7
Potential difference between the center of a sphere and a point 4.0 cm away?
- hidemi
- · Replies 7 ·
- Replies
- 7
Potential difference between the surface of a sphere and a point far away
- songoku
- · Replies 13 ·
- Replies
- 13
Potential difference between two points in a loop
- Jahnavi
- · Replies 14 ·
- Replies
- 14
Circuit with potential difference across battery being zero?
- zenterix
- · Replies 3 ·
- Replies
- 3
Potential difference between two points on a circuit
- terryds
- · Replies 7 ·
- Replies
- 7
