gracy
- 2,486
- 83
I also have to show charge distribution on capacitor plates.
We didn't have to. We simply followed the instructions from gneill in #82.gracy said:But we did not use voltage divider rule anywhere.
cnh1995 said:It will be not as straightforward as it is for resistors. Because resistors is series add directly while capacitors in series don't.. You can derive it but can't memorize it because it will change with number of capacitors.
But I want to learn,I will create a separate thread on it.cnh1995 said:We didn't have to
Can we solve all the problems with these steps that can be solved with voltage divider rule ?cnh1995 said:We simply followed the instructions from gneill in #82.
You can do that using the information you calculated (the Q on each capacitor).gracy said:I also have to show charge distribution on capacitor plates.
You used the general voltage divider principle though, which boils down to the voltage divider rule when only two components are involved. The general principle is more flexible and can be applied in more situations without having to memorize a bunch of different formulas.gracy said:But we did not use voltage divider rule anywhere.
Yes. Actually voltage divider rule for resistors is nothing but these steps. You can verify.gracy said:Can we solve all the problems with these steps that can be solved with voltage divider rule ?
Right.gracy said:VR1V_{R1} = VinV_{in} R1R1+R2+Rj+R(n−1)+Rn\frac{R1}{R1 + R2+R_j+R_(n-1)+R_n}
Right?
That's because series capacitors don't add directly.gracy said:I am unable to write the same for capacitors
I believe the summation part in the numerator should be in the denominator. Also, you can verify this formula by putting n=2.gracy said:I'll give it a try
VC1V_{C1}=VinV_{in} C2CjCn−1Cn+C1CjCn−1Cn+C1C2Cn−1+Cn+C1C2CjCn+C1C2CjCn−1C1C2CjCn−1Cn
gracy said:in the picture why ##V_{Rn}## =##I####R_n## and ##V_{Cn}##=##\frac{Q}{C_n}## is not shown
Any random element ?ehild said:i-th element
Yes, thank yougracy said:Should not it be ##V_i##=Q/##C_i##=##V_{in}####\frac{1/C_i}{1/C_1+1/C_2+...+1/C_n}##
