B What is the 'proof' of the no-hair theorem of black holes?
The discussion centers on the no-hair theorem of black holes, which asserts that stationary black holes are characterized solely by mass, angular momentum, and electric charge. Stephen Hawking, along with Israel, Carter, and Robinson, contributed to proving this theorem, but the original proof is not contained in a single paper authored by all four. Instead, their work is spread across multiple publications, with each scientist addressing different aspects of the theorem. A significant point raised is the issue of Hawking's assumption of analyticity, which some consider unreasonable, leaving the problem open in mathematical literature as the rigidity conjecture. The thread concludes with a note that the topic is complex and not suitable for basic-level discussion, prompting the closure of the thread.
Cerenkov
Hello.
In chapter 3 (Quantum Black Holes) of this book... https://www.amazon.com/dp/069116844X/?tag=pfamazon01-20 ...Stephen Hawking writes...
"The no-hair theorem, proved by the combined work of Israel, Carter, Robinson and myself, shows that the only stationary black holes in the absence of matter fields are the Kerr solutions. These are characterized by two parameters, the mass M and the angular momentum J. The no-hair theorem was extended by Robinson to the case where there was an electromagnetic field. This added a third parameter Q, the electric charge."
My questions concern what Hawking meant by the words, '...proved by the combined work of..'
Is there a single paper where these four scientists worked together to offer up said proof?
If so, could I please be directed to it?
Or, is there somewhere that I can find the proof 'combined' from the work of these four?
Any help given at a Basic level would be appreciated.
Thank you,
Cerenkov.
Space news on Phys.org
Israel, W., (1967). “Event horizons in static vacuum spacetimes”, Phys. Rev. 164, 1776.
Israel, W., (1968). “Event horizons in static electrovac spacetimes”, Commun. Math. Phys. 8, 245.
Kerr, R. P., (1963). “Gravitational field of a spinning mass as an example of algebraically special metrics”, Phys. Rev. Lett. 11, 237.
Many thanks for this info, thierrykauf!
Likes thierrykauf
martinbn said:
an analyticity, assumption which is unreasonable both mathematically and physically
The links you give don't go into any detail about why this is. Is there a simple explanation of why analyticity is unreasonable as an assumption?
This really isn't a "B" level topic (it's at least "I" and probably "A"--certainly the references given so far are "A").
For that reason, this thread is now closed since the OP has been given references. (I have a further question about the references @martinbn posted, but I'll start a new thread for that.)
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
Why was the Hubble constant assumed to be decreasing and slowing down (decelerating) the expansion rate of the Universe, while at the same time Dark Energy is presumably accelerating the expansion? And to thicken the plot. recent news from NASA indicates that the Hubble constant is now increasing. Can you clarify this enigma? Also., if the Hubble constant eventually decreases, why is there a lower limit to its value?
