What is the rate of water decreasing in a hemisphere bowl when the depth is 6cm?
  • Thread starter Thread starter Ose90
    Application
The discussion centers on calculating the rate at which water decreases in a hemisphere bowl with a radius of 12 cm, initially full of water. The water exits through a hole at a rate of 48π cm³/s. It is established that the depth of the water, denoted as x cm, decreases at a rate of 48/[x(24-x)] cm/s. Specifically, when the bowl is full, the depth decreases at 1 cm/s, and when the depth is 6 cm, the rate of decrease is 2/3 cm/s.
  • Understanding of calculus, specifically related rates
  • Familiarity with the geometry of a hemisphere
  • Knowledge of volume formulas for solids of revolution
  • Ability to apply the chain rule in differentiation
  • Study the application of related rates in calculus problems
  • Learn about the volume of a hemisphere and its derivatives
  • Explore the use of implicit differentiation in geometric contexts
  • Investigate real-world applications of fluid dynamics in containers
Students and educators in calculus, engineers dealing with fluid dynamics, and anyone interested in mathematical modeling of physical systems.
Ose90
A hemisphere bowl of radius 12cm is initially full of water. Water runs out of a small hole at the bottom of the bowl at a rate of 48pi cm^3 s^-1. When the depth of the water is x cm , show that the depth is decreasing at a rate of 48/[x(24-x)] cm s^-1
Also, find the rate at which the depth is decreasing when
a) The bowl is full.
b)The depth is 6cm.
Another question is in this picture
Thanks in advance! Really urgent :)
Hi Ose90! :smile:
Show us what you've tried, and where you're stuck, and then we'll know how to help. :smile:
tiny-tim said:
Hi Ose90! :smile:
Hi tiny-tim, thanks for replying.
Glad to tell you that I have solved it.
However, I will still write down my solution to see if it is correct.
For the first question, I imagine the right side of the semi-circle displaced vertically, I get the equation (x-0)^2 + (y - r)^2 = r^2
then, x^2 = r^2 - (y^2 + r^2 -2yr)
x^2 = r^2 - y^2 -r^2 +2yr
= 2yr - y^2
x = [y(2r - y)]^(1/2)
Hence, when h = x and r = 12 , dV/dx = pi(24x-x^2)
from the question , dv/dt =48 pi
dx/dt = dx/dv x dv/dt
= 48 pi
pi(24x - x^2)
For the second question , I use similar triangle to solve it.
Thanks!
