What is the relationship between atomic density and mass density in aluminum?
  • Thread starter Thread starter mvr01
    Atomic Density
The discussion revolves around the relationship between atomic density and mass density in aluminum, focusing on how to calculate mass density given an atomic density value. Participants explore the formulas involved and the necessary conversions, with a mix of theoretical understanding and practical calculations.
  • Homework-related
  • One participant asks how to calculate mass density from an atomic density of 6.04 X 10^22, indicating confusion about the relationship between the two densities.
  • Another participant provides a formula for mass density, relating it to the number density and the mass of one atom, suggesting that mass density can be calculated using the equation ρ = m₀ * n₀.
  • Subsequent replies attempt to calculate mass density using the provided atomic density and atomic mass, with one participant proposing a calculation that yields a mass density of 2.7 g/cm³.
  • Another participant points out the need to clarify the volume associated with the atomic density to ensure correct units for mass density.
  • One participant expresses confusion over their calculations, presenting multiple results for mass density and seeking clarification on the correct approach.
  • A later reply emphasizes the importance of specifying units for atomic density to avoid incorrect results.
  • Participants discuss the implications of measuring bulk material density versus atomic density, suggesting a comparison with known values for aluminum density.
Participants express varying levels of understanding and arrive at different calculations for mass density, indicating that there is no consensus on the correct approach or final value at this time.
Some participants note the importance of units in calculations, and there are unresolved issues regarding the correct volume associated with the atomic density provided. The discussion reflects a mix of correct and incorrect assumptions about the relationships between the quantities involved.
mvr01
Can anyone help.
How do I calculate mass density of aluminium, given the atomic density of 6.04 X 10^22.
I understand that Density = Mass/Volume. but the question confuses me.
Thanks
Chemistry news on Phys.org
the mass density is equal to:
[tex] \rho = \frac{\Delta m}{\Delta V}[/tex]
where [itex]\Delta m[/itex] is the mass contained in the volume [itex]\Delta V[/itex]. But, at the same time, the total mass is equal to:
[tex] \Delta m = m_{0} \, \Delta N[/tex]
where [itex]m_{0}[/itex] is the mass of one particle (atom, molecule) and [itex]\Delta N[/itex] is the total number of particles in that volume. So, we can write:
[tex] \rho = \frac{m_{0} \, \Delta N}{\Delta V} = m_{0} \, \frac{\Delta N}{\Delta V}[/tex]
But, by definition, the number density is:
[tex] n_{0} \equiv \frac{\Delta N}{\Delta V}[/tex]
So, we have:
[tex] \rho = m_{0} \, n_{0}[/tex]
So, all you need is to find the mass of one atom of aluminum. You will need to review the concept of atomic mass unit and relative atomic (molecular) mass.
Thanks dickfore...
so is this right?
p = (6.04 X 10^22 / 6.023 X 10 ^23) x 26.98 = 2.7g
mvr01 said:
Thanks dickfore...
so is this right?
in what volume are there [itex]6.04 \times 10^{22}[/itex] particles? You will need to divide with that volume to get a density. As it is now, your result has units of mass.
Sorry,, I hope I am not annoying you. I am getting mixed answers. Can you please work it out for me...
Im gettng volume of 6.04 X 10^22 = 4.470 X10^-23, therefore the mass density equaling 3.645 X 10^46..
or
(6.04 X 10^22 / 9.98 ) X 26.98 = 1.6g/cm^3
Im lost
no, i won't. In your original post, you hadn't specified a correct unit for the number density of Al atoms. This is why your mass density is in incorrect units. You should look back in your problem formulation again.
Yes you're right,,, The question is the atomic density of 6.04 X 10^22 atoms per cm^3.
I missed out the units.
so would this mean, (6.04 X 10^22 cm^3 / 1.023 X 10^23) x 26.98 amu = 2.7 g/cm^3
yes. look up density of aluminum and you compare with what you have found. However, I urge you to think about which one is easier to measure, the density of a bulk material or the number density of the atoms in the material?
  • · Replies 0 ·
  • · Replies 24 ·
