What is the relationship between F-number and light intensity in camera lenses?
The discussion revolves around the relationship between the f-number of camera lenses and light intensity, exploring the underlying equations and derivations related to optics. Participants examine the proportionality of light intensity to various parameters, including aperture diameter and focal length, while addressing misconceptions and clarifying definitions.
  • One participant questions the equation stating that light intensity is proportional to \(\frac{D^2}{f^2}\) and seeks its derivation.
  • Another participant expresses skepticism about the equation, suggesting that it is cumbersome and that light intensity is typically described as proportional to \(1/f^2\).
  • Some participants note that photography texts mention a change in intensity with aperture adjustments but do not provide derivations.
  • A participant points out a potential misunderstanding regarding the definition of the f-number, clarifying that it is the inverse of the ratio of focal length to aperture diameter.
  • Concerns are raised about the interpretation of diagrams and equations from external sources, with some participants struggling to reconcile their understanding with the presented information.
  • There is a discussion about how the area of the lens affects light collection and how the intensity of light at the image is influenced by the area of the image sensor.
  • Some participants explore the implications of object distance and its relationship to focal length in determining image intensity.
  • One participant acknowledges a mistake in their reasoning regarding the relationship between focal length and image intensity after receiving clarification from another participant.
Participants express differing views on the correct interpretation of the relationship between f-number, aperture, and light intensity. There is no consensus on the derivation of the equations or the validity of the claims made regarding light intensity.
Some participants highlight limitations in their understanding of the derivations and the diagrams referenced, indicating that certain assumptions may not have been fully addressed or clarified.
r4nd0m
I've been searching through the internet and some of my optics books, but nowhere was I able to find the derivation of the law for a camera lens, that the intensity of light that comes on the film or chip is proportional to \frac{D^2}{f^2}=N^2, where D is the aperture diameter, f the focal length and N the f-number. Any ideas?
Science news on Phys.org
I've seen that equation only a few times and I'm not sure I agree with it. For one thing, it seems needlessly cumbersome since diameter is part of focal ratio. Where, exactly, did you get it?
Typically, optics texts should tell you that the intensity of light is proportional to 1/f^2
Well, it's actually in most of the books on photography, but it's never derived. They say, that when you change the aperture by a factor of sqrt(2), the intensity of light will change by factor 2.
Something is wrong with this equation. Are you sure N is not an inverse of f-number (I will denote it by f/#)?
First of all, by definition f/#=f/D, so it is eaxactly opposite with N=D/f (squares ignored, but they don't change anything here).
Second, amount of light passing through the lens is not directly proportional to f/# but inversely proportional to f/# (for the sake of simplicity I am again ignoring squares). The higher the f/#, the less light passes through the lens - but the equation as listed states that there is more light.
That's obvious - amount of the light passing through the lens is proportional to the area of the hole, this is in turn proportional to diameter squared. See the definition and it should click.
ooops, you're right of course, N is the inverse of the f-number.
Anyway, I still seem to misunderstand something. I found this 'derivation' of the equation, here: http://www.inyourfacefotos.com/fstop.htm , although I quite don't understand some of the steps there (even if it's elementary school algebra).
Well, first of all, according to the first picture and the equations, the intensity of light at the image is proportional to f^2 (not inversely proportional). The equations are OK, so there must be something wrong with the picture, but I can't figure out what it is.
Then I don't understand how they got the second equation in the section "aperture stops" (I_i = ...). It just doesn't make any sense to me.
When I tried to derive it myself according to the second picture, I started with I_i = I_0 \frac{A_a}{A_i} from which I obtained I_i = I_0 \frac{f^2}{x_i^2}, which is probably not true.
I feel really stupid for not understanding such an elementary thing, but I'm probably missing something essential.
Sorry, I read your first post too fast and didn't see that "f" was focal length, not focal ratio. That equation looks right, then.
I'm having a tough time parsing your question, which seems to be "why is the incidance proportional to the square of the f-number?" (Incidance is the amount of light incident onto a surface). If that's the case, then the answer is most liklely because the f-number depends on the radius (or diameter) of the lens; thus the total collection area of the lens (the area) is proportional to the square of the radius, i.e. the square of the f/#.
The intensity of the light at the image is proportional to the area of the lens: if the lens has twice as much area, it collects twice as much light.
For a given lens area, the intensity of the light is inversely proportional to the area of the image: if you take a given amount of light and deposit it onto half the sensor area, you get twice the intensity.
Usually, with a camera, the object distance (from the lens) is much longer than the focal length, so the image distance very nearly equals the focal length. In this situation, the height and width of the image are very nearly proportional to the focal length. Therefore the intensity of the light at the image is very nearly inversely proportional to the square of the focal length.
This is perfectly clear.
This is the critical point. Let's say that the heigth of the object is y_0, the focal length is f, and the distance from the focal point to the film is x_i (as in the first picture in http://www.inyourfacefotos.com/fstop.htm). Then by similarity of triangles the heigth of the image will bee y_i=\frac{y_0}{f} x_i, that is it will be inversely proportional to f and thus the intensity I \propto f^2. The question is what is wrong in this reasoning?
That diagram isn't really appropriate for this question. Try the attached one instead. For an object of given size and distance from the lens, the angle \theta is fixed. Looking at the red triangle, it should be obvious that if \theta is fixed, then the image height h_i is proportional to the image distance d_i. If the object distance is much larger than the focal length, then the image distance is practically equal to the focal length. Therefore the image height is practically proportional to the focal length.
Aah, I see, the problem with my formula was that if I changed f, x_i would change too. Your picture, jtbell, explains it very well. Thank you very much for your time.
