What is the Second Derivative of 2xy - y^3 = 5?
  • Thread starter Thread starter LearninDaMath
The discussion revolves around finding the second derivative of the implicit equation 2xy - y³ = 5. Participants are exploring the implications of differentiating an equation involving two variables and the correct application of implicit differentiation.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants discuss the correctness of their derivatives and the implications of treating the equation as a function of two variables. There are questions about the proper notation and the steps involved in implicit differentiation.
Some participants have provided hints regarding potential mistakes in the differentiation process. Others are questioning the interpretation of the equation and whether it should be treated as a function of two variables, leading to further exploration of implicit differentiation.
There is a noted confusion regarding the notation used for derivatives and the nature of the equation itself, with some participants emphasizing the need to clarify the relationship between x and y in the context of implicit differentiation.
LearninDaMath
Here is my work/attempt. In blue is my answer. In green is the supposed correct answer.
The first derivative is surely correct, as it matches the answer I was supposed to get. However, if my second derivative answer is incorrect, can you determine where I I am making a mistake?
Here's a hint: your mistake comes on the third to last step (the line beginning f''(x) = -2(-2y)
Would it be correct to approach this step like this:
EDIT: On the first line, please regard the 12y^2 as just 12y. The second line is written as though the 12y is what I started off with.
Your mistake is in the 3rd to last step, where you have one term with a 2x-3y^2 denominator. In the following step you simplified the equation by multiplying (2x-3y^2) with the (2x-3y^2)^2 term. However the two 4y terms on the numerator were not being divided by 2x-3y^2.
Would this be the correct way to do that step?
Okay, I was able to get the answer in the right form as the provided answer. However, it is off numerically by 2. The provided answer has 18xy and my answer has 16xy. I have always known 8 + 8 to equal 16...what gives?
Some comments.
1) You don't take "f' " of an expression. f'(x) is the derivative of f. The operator is d/dx. f' and f'' should not appear in your work at all.
2) You wrote f(x) = 2xy - y3 = 0. This is incorrect because a) the expression 2xy - y3 involves both x and y, not just x alone, and b) the equation 2xy - y3 = 0 defines an implicit relationship between x and y.
Ah, that's right. It's not a function is it. It's an equation, but not a function. Appreciate the input.
As Mark44 said, it's an implicit relationship. Correct me if I'm wrong, but doesn't the question seem a little strange? How can
[itex]f(x) = 2xy - y^{3} = 5[/itex]?
That being the case, wouldn't we need to write
[itex]f(x,y) = 2xy - y^{3} = 5[/itex], or [itex]f(x,y) = 2xy - y^{3} - 5[/itex]
since it is a function of two variables? Then we would just need to find [itex]\frac{\partial f}{\partial x}[/itex] and [itex]\frac{\partial f}{\partial y}[/itex]. If this isn't the case, we would just have
[itex]2xy - y^{3} = 5[/itex],
and we would need to find [itex]\frac{dy}{dx}[/itex] implicitly, not f'(x).
So guys, which is it? Or am I completely off on this one?
No, I think you are on track here. f'(x) is meaningless here, since the left side of the equation 2xy - y3 - 5 = 0 represents a function of two variables.
The tacit assumption here, I believe, is that y is an implicit function of x, and goal is to find dy/dx using implicit differentiation. Note that this should be written as dy/dx = ..., not f'(x) = ..., so as to not cause confusion between the function (of two variables) in the first equation, and the function (of one variable) that relates x and y.
After dy/dx has been found, differentiate again to find d2y/dx2.
