What is the simplest way of selecting the last N terms of a polynomial?
In summary, the conversation discusses a function for selecting the last N terms of a polynomial. The function is defined as F_k(p) = (p_n, p_{n-1}, ..., p_{n-k}) and is considered the simplest way to achieve this. However, it only works for polynomials in the form (1 + x)^n. The use of the "Pascal's triangle" is also suggested as an alternative.
kaleidoscope
66
If you have a polynomial like (1+x)^6 = x^6+6 x^5+15 x^4+20 x^3+15 x^2+6 x+1, What function would you use to pick only the last N terms? For instance, for N=3 pick x^6+6 x^5+15 x^4
I've being using sum of a binomial times something, but was wondering if there is anything more simple.
Thanks!
Mathematics news on Phys.org
What do you mean by "to pick"? Can you state your question mathematically?
Here:
where
for example:
tex?\dpi{150}%20(x+1)^3=\binom{3}{0}+\binom{3}{1}x+\binom{3}{2}x^2+\binom{3}{3}x^3=1+3x+3x^2+x^3.gif
^ I think he might just mean an (ordered) set of terms from the polynomial. The order is established by listing the coefficients in descending order of their degree.
I think what you want isn't so complicated. It's as follows: if [itex]p \in \mathbb{R}\left[x\right][/itex] is a polynomial with degree n, i.e. [itex]p(x) = {p_n}{x^n} + {p_{n - 1}}{x^{n - 1}} + ... + {p_1}x + p_0[/itex], define the function [itex]F_k: \mathbb{R}\left[x\right] \rightarrow \mathbb{N}^k[/itex] by [itex]{F_k}(p) = (p_n, p_{n - 1}, ..., p_{n - k})[/itex]. This "gets" the first (or if you want, last) k coefficients, which is really all you need to define a polynomial.
Black Integra said:
Here:
where
for example:
Exactly! This is the function I've being using. What I wonder is if there is a more simple version of it.
Thank you very much anyways!
I think it's the simplest way. May be, if you don't want to deal with combinatorics, use "[URL triangle[/URL]
That only works for polynomials which can be expressed in the form (1 + x)n, though ...
Related to What is the simplest way of selecting the last N terms of a polynomial?
1. What is a polynomial?
A polynomial is a mathematical expression that consists of variables and coefficients, combined using only addition, subtraction, and multiplication operations. It can have one or more terms, and each term can have a different degree.
2. How do you find the last N terms of a polynomial?
To find the last N terms of a polynomial, you can use the concept of degree and coefficients. The degree of a term is the highest power of its variable, and the coefficient is the number that multiplies the variable. You can start from the highest degree term and count N terms backward to get the last N terms of the polynomial.
3. What is the simplest way of selecting the last N terms of a polynomial?
The simplest way of selecting the last N terms of a polynomial is by using the polynomial's degree and coefficients. You can start from the highest degree term and count N terms backward to get the last N terms of the polynomial.
4. Are there any other methods for selecting the last N terms of a polynomial?
Yes, there are other methods for selecting the last N terms of a polynomial. One method is by using the polynomial's end behavior. The end behavior of a polynomial is determined by its leading term, which is the term with the highest degree. The end behavior can help identify the last few terms of a polynomial.
5. Why is it important to know how to select the last N terms of a polynomial?
Knowing how to select the last N terms of a polynomial is essential because it can help in simplifying and solving polynomial equations. By selecting the last N terms, you can identify the most significant terms of a polynomial and focus on them while solving equations. It can also help in understanding the behavior of a polynomial at its end, which is crucial in many applications.
  • General Math
  • General Math
9K
