What is the solution to Dido's problem?
  • Thread starter Thread starter pilpel
The discussion centers on Dido's problem, which seeks the geometric shape that maximizes area given a fixed perimeter with one side as a straight line. While sources suggest a semi-circle is the optimal solution, calculations show that a full circle provides a larger area when not constrained by a straight edge. However, since Dido's problem specifies a straight side, a semi-circle cannot be the answer. The conclusion is that for Dido's problem, the optimal shape is not a circle but rather a semi-circle due to the straight edge requirement. Understanding the constraints is crucial for determining the correct geometric solution.
pilpel
Given a fixed perimeter, what is the geometric shape (non-self-intersecting closed curve) that would maximize the enclosed area? MathWorld (I'm not allowed to link) and a few other sites insist that the answer is a semi-circle, but simple math with perimeter=100 m would show that a circle would have area 2500/\pi\approx795.8 m^{2} whereas a semicircle wold have area \approx594.2 m^{2}.
What am I missing?
Mathematics news on Phys.org
Dido's problem demands that one side of the enclosure is a straight line of fixed length. A circle would not qualifiy, since it has no straight sides.
If you allow all closed curves, then the circle would be optimal.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
