What is the speed of recoil of the chair and cat?
  • Thread starter Thread starter Sneakatone
    Speed
The discussion centers on calculating the recoil speed of a chair when a cat jumps onto it. The cat, weighing 6.4 kg, jumps from a distance of 1.7 m and lands with zero vertical velocity, causing the chair, which weighs 12 kg, to roll away. The calculations involve determining the horizontal velocity of the cat and applying the conservation of momentum for the inelastic collision between the cat and chair. The final speed of the chair and cat moving together is found to be approximately 2.99 m/s. The conversation confirms the use of momentum conservation rather than the center of mass equation for this scenario.
Sneakatone
A cat crouches on the floor at a distance of 1.7 m from a desk chair of height 0.45 m. The cat jumps onto the chair , landing with zero vertical velocity. The desk chair has coasters and rolls soomthly away when the cat lands. The cats mass is 6.4 kg , the chairs mass is 12 kg. what is the speed of recoil of the chair and cat?
1/2gt^2=0.45m
t=0.303s
1.7/0.303=5.61ms horizontal velocity component
5.61*6.4=12v
v=2.99m/s
Sneakatone said:
1/2gt^2=0.45m
t=0.303s
So far, so good.
5.61*6.4=12v
After the "collision" the chair and cat move as one body.
so would it be 5.61*6.4=(12+6.4)v?
That's correct.
thank you!
was that center of mass equation used or was that m1v11=m2v1?
Sneakatone said:
thank you!
That was conservation of momentum applied to an inelastic collision.
m1v1 + m2v2 = (m1 + m2)vf
(Here, v2 = 0, since the chair was initially at rest.)
I see now,
thank you very much!
