What Is the Tension in the Remaining String After Cutting One Support?
  • Thread starter Thread starter franniemeow07
    Meter Tension
The discussion centers on calculating the tension in the remaining string of a meter stick supported by two strings after one is cut. When the left string is severed, the stick pivots around the 90 cm mark, requiring the use of torque equations to determine the tension. Participants clarify the appropriate moment of inertia formula, emphasizing the need for the parallel axis theorem rather than the standard formulas provided. The stick is confirmed to be horizontal prior to cutting, which is crucial for accurate calculations. Ultimately, the user successfully identifies the correct moment of inertia and tension calculation method.
franniemeow07
Hi, this question was from an archived thread but I have another relevant question that was not answered by any of the posters--
P.S. The answer to c is NOT mg.
A meter stick (L = 1 m) with mass M = 0.409 kg is supported by two strings, one at the 0 cm mark and the other at the 90 cm mark.
c) Now the string at 0 cm is cut. What is the tension in the remaining string immediately thereafter?
I got parts a and b figured out, but I can't get c...Can I please get some help...
When the left string is cut, the stick pivots about the 90cm mark. Take torques about that point:
(1) mgx = I α (Where "x" is the distance from the pivot to the center of mass of the stick; I is the rotational inertia of the stick about the pivot.)
Note that the acceleration of the c.m. is related to α by a = αx. Thus you can solve for "a".
Now consider the forces acting on the stick:
(2) mg - T = ma
This will give you T, the tension in the remaining string.
What formula for I should I use, I = (1/3)ML^2, or I = (1/12)ML^2?
Also, should L be equal to "x", the distance from the pivot to the center of mass, or should it be 1meter?
It would be helpful if you posted the whole question, even if you do know how to do part of it. I will assume the stick is horizontal before the string is cut. If it's not, that could affect the outcome.
As for the moment if inertia, it is neither of the choices you listed. You will need to use the parallel axis theorem to find the appropriate I.
http://hyperphysics.phy-astr.gsu.edu/hbase/parax.html
I'm sorry, you assumed right, the stick is horizontal before the string is cut. I guess I forgot to post the diagram :-p
THANK YOU SO MUCH, you are awesome! I figured out the I, it's just the Icm+Mx^2, and yes, I do use x as r, in calculating a = alpha / r. YAYYY :smile:
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
