What Is the Time Constant and Potential Difference in This RC Circuit?
6 replies · 2K views
letsgo
Consider the circuit below, where C1=80mF, C2=30mF, R=50ohms and E=5V.
At t=0, both capacitors are uncharged - so it's charging.
The circuit is in series, with E ---> C1 ---> C2 ---> R ---> (back to) E
a) Find the time constant.
b) The initial potential difference across R.
c) The current at t=3s.
d) The potential difference across C2, at t=3s.
C=Q/V
V=IR
X=Xmax(e^(-t/RC)) (where X is I, V or Q and is decreasing with time)
X=Xmax(1 - e(-t/RC)) (where X is I, V or Q and is increasing with time)
Here are my answers, can someone check if I'm right?
a)
time constant = RC = (50 ohms)(21.8 mF) = 1.09 s
b)
V=5.0 ohms (same as E)
c)
V=RI -> 5V=(50 ohms)I -> I=0.1 A
I=Imax(e-t/RC)
I=(0.1 A)[/SUB](e(-3s/1.09s))
I=6.37x10-3 A
d)
VCeq= Vmax(1-e-t/RC)
VCeq= (5 V)(1-e-3s/1.09s)
VCeq= 4.68 V
V=C/Q -> 4.68V=30mF/Q -> Q=6.4x10-3 C
So are the other answers good to?
lewando said:
b) I know you meant V not ohms
c) good
d) looking for a voltage across C2, VCeq is right though.
Thanks. And OK, you're right, I fixed it.
V=Q/Ceq
4.68=Q/21.8mF
Q=1.02 C, which is the same across each capacitor since they're in series.
And can you please, since you seem to know what you're talking about when it comes to RC circuits, answer this question of mine as well?
https://www.physicsforums.com/showthread.php?t=648367
for d) you need to determine the voltage across C2. It is done the same way as if you were going a resistor divider.
On your other question, gneill is on it (and will advise you well).
