What Is the Time Constant and Potential Difference in This RC Circuit?
The discussion revolves around an RC circuit with two capacitors and a resistor, where participants are tasked with finding the time constant, initial potential difference, current at a specific time, and potential difference across one of the capacitors. The circuit parameters include capacitances of 80mF and 30mF, a resistance of 50 ohms, and a voltage source of 5V.
  • Participants discuss the calculation of the time constant and potential differences in the circuit. There are attempts to verify the correctness of the original poster's calculations, particularly regarding the time constant and the voltage across the capacitors. Questions arise about the interpretation of voltage and current values at specific times.
Some participants have provided feedback on the calculations, indicating that certain values appear correct while others may need clarification. There is ongoing exploration of the voltage across the second capacitor, with references to similar methods used for resistor dividers. Participants are engaging with each other's insights and corrections.
There are mentions of potential misunderstandings regarding units and the need for clarity in the calculations. The original poster's request for further assistance on a related question suggests a desire for deeper understanding of the concepts involved.
letsgo
Consider the circuit below, where C1=80mF, C2=30mF, R=50ohms and E=5V.
At t=0, both capacitors are uncharged - so it's charging.
The circuit is in series, with E ---> C1 ---> C2 ---> R ---> (back to) E
a) Find the time constant.
b) The initial potential difference across R.
c) The current at t=3s.
d) The potential difference across C2, at t=3s.
C=Q/V
V=IR
X=Xmax(e^(-t/RC)) (where X is I, V or Q and is decreasing with time)
X=Xmax(1 - e(-t/RC)) (where X is I, V or Q and is increasing with time)
Here are my answers, can someone check if I'm right?
a)
time constant = RC = (50 ohms)(21.8 mF) = 1.09 s
b)
V=5.0 ohms (same as E)
c)
V=RI -> 5V=(50 ohms)I -> I=0.1 A
I=Imax(e-t/RC)
I=(0.1 A)[/SUB](e(-3s/1.09s))
I=6.37x10-3 A
d)
VCeq= Vmax(1-e-t/RC)
VCeq= (5 V)(1-e-3s/1.09s)
VCeq= 4.68 V
V=C/Q -> 4.68V=30mF/Q -> Q=6.4x10-3 C
τ(seconds) = resistance(ohms) * capacitance(Farads). Your result is a bit too big.
Nevermind,τ looks good.
So are the other answers good to?
b) I know you meant V not ohms
c) good
d) looking for a voltage across C2, VCeq is right though.
c) good
Thanks. And OK, you're right, I fixed it.
V=Q/Ceq
4.68=Q/21.8mF
Q=1.02 C, which is the same across each capacitor since they're in series.
And can you please, since you seem to know what you're talking about when it comes to RC circuits, answer this question of mine as well?
https://www.physicsforums.com/showthread.php?t=648367
for d) you need to determine the voltage across C2. It is done the same way as if you were going a resistor divider.
On your other question, gneill is on it (and will advise you well).
9K
