MHB What is the total area of the doors and windows in the room?
drewcifur
I am having trouble figuring out the answer to the following question, I am not sure how to get to my answer.Calculate the area of each wall, including any doors and windows (The room is rectangular in shape. The floor is 18 ft. 5 in long by 9 ft 6 in wide. All of the walls are 8 ft high. You will not paint the windows nor the doors. There are two doors each of which is 7 ft 3 in. high by 3 ft wide. One window is 4 ft wide by 5 ft. high. There are also two windows that are 2 ft 6 in wide by 5 ft high)
Mathematics news on Phys.org
Let's ignore the doors and windows for now. You have 4 walls, which are rectangular. The walls opposite each other have identical areas. Can you find the total area of the 4 walls?
the formula it says to use to find the area of one wall is L x W x H, since i am only given the height of the wall (8ft) i figure
I should use the dimensions of the floor for L and W but I am thrown off by having to multiply foot and inch together rather than just, for example, (18 ft length 9 ft width) I have tried to convert to decimal and solve that way but my answers do not look right
The formula for the area of a rectangle is:
$$\text{Area}=\text{base}\times\text{height}$$
or:
$$A=bh$$
The height of each rectangle is 8 ft, as we are told all walls are 8 ft tall. The bases of the rectangular walls we get from the given dimensions of the floor, as you surmised.
And so we will have two walls whose bases are:
$$18\text{ ft}\,5\text{ in}=\left(18+\frac{5}{12}\right)\text{ ft}=\frac{221}{12}\,\text{ft}$$
And we will have two walls whose bases are:
$$9\text{ ft}\,6\text{ in}=\left(9+\frac{6}{12}\right)\text{ ft}=\frac{19}{2}\,\text{ft}$$
Now, if we add these all up, then the total area \(A\) of the 4 walls is then:
$$A=2\left(\frac{221}{12}\,\text{ft}\right)\left(8\text{ ft}\right)+2\left(\frac{19}{2}\,\text{ft}\right)\left(8\text{ ft}\right)$$
Let's factor this:
$$A=2(8)\left(\frac{221}{12}+\frac{19}{2}\right)\text{ ft}^2$$
Adding the fractions, and computing the product of the first two factors, we can write:
$$A=16\left(\frac{335}{12}\right)\text{ ft}^2$$
Reduce:
$$A=\frac{4\cdot335}{3}\,\text{ft}^2=\frac{1340}{3}\,\text{ft}^2$$
Before we proceed, does all this make sense so far?
or:
$$A=bh$$
Let's factor this:
Reduce:
yes so far i am understanding a bit more clearly
Okay, now we need to compute the total area of the windows and doors. What do you get for that?
i'm not sure I'm right but I for the area of the doors I got 7ft 6in (7.5) and for the windows I have the first window an area of 20 ft and the two other windows with an area of 12 ft 6 in (12.5)
You are finding areas, so you want your units to be $$\text{ft}^2$$, because you are multiplying two linear measures in units of $$\text{ft}$$.
There are 2 doors of equal measure and so the area \(A_D\) of the doors is:
$$A_D=2(3\text{ ft})\left(\left(7+\frac{1}{4}\right)\text{ft}\right)=?$$
